compression / depression
Old Aug 29, 2009 | 11:07 PM
snake skin's Avatar
snake skin
Stage II
Default compression / depression
Rebuilt my 1982 xl1000 with new crank, bored out jugs to 50 over with new pistons and had new valves and guides put in, But only get 50lbs of compression in both cyclinders, Why?
Old Aug 29, 2009 | 11:11 PM
snake skin's Avatar
snake skin
Stage II
Rehoned cyclinders, new rings agin. checked timing agin, installed new gasket set agin, still same compression problem, and no one seems to have any good answer as to why.
Old Aug 29, 2009 | 11:16 PM
codyshop's Avatar
codyshop
This is with the throttle held wide open? Also, Sportsters are notoriously difficult to cam-gear time, so I'd check that also.
Old Aug 29, 2009 | 11:17 PM
treefiddy's Avatar
treefiddy
Compression tester in good condition? Maybe it has a leak, good luck!
Old Aug 30, 2009 | 05:21 AM
Thundermug's Avatar
Thundermug
Same reading on both cylinders? could be cam timing, or bad tester....or misaligned valve guides on both heads (nearly improbable)
Old Aug 30, 2009 | 07:28 AM
flibuoy's Avatar
flibuoy
Smile
two posts 4 minutes apart? did you put the heads back on?
You might try reposting in a tech section where it is more likely to have a good wrencher see the post. If you put the heads back on....right size pistons... then it pretty well narrows it to valve timing...or pushrods are not correct length holding valves open but that seems unlikely if engine turns ok....maybe a search would turn up some good suggestions...
Old Aug 30, 2009 | 07:49 AM
1flhtk4me's Avatar
1flhtk4me
I would check the cam timing also.
You could also remove the valve covers to see if the the valves are closed at TDC.
Old Aug 30, 2009 | 08:57 AM
dennyo's Avatar
dennyo
scootertramp
Ironhead
Feb 3, 2010 06:52 AM
diamond83
Ironhead
Jul 24, 2009 01:56 PM
AmericanNightmare73
Ironhead
Apr 20, 2009 09:45 PM
RichLo
Ironhead
16
Dec 10, 2008 11:31 AM
straydog13
Ironhead
11
Sep 10, 2008 06:03 PM
