Ironhead A place to talk about Ironheads.
compression
Old Jul 24, 2009 | 07:22 AM
diamond83's Avatar
diamond83
3rd Gear
Default compression
I finally got my bike together after working on it all winter. I ran it for a week on the stand and it sounded great. I took it off and rode it. I got 5 miles on it and it started spitting and back firing so I brought it back and checked it out. I lost compression on my front cylinder, I mean 0 comp. I don't understand what happened can anyone help.
Old Jul 24, 2009 | 12:29 PM
piniongear's Avatar
piniongear
If you have zero compression then you have a huge problem on your hands.
I would first check the push rods to make sure they are not tight (keeping the valves open) and then start removing the front head.
In any case this is not good news. Whatever happened at the very least there is valve damage. And, there could be that, plus a hole in the piston. That will be about the worst situation, so I hope that is not the case.......... pg
Old Jul 24, 2009 | 01:51 PM
db45's Avatar
db45
Drain your oil. if it smells like gas compression is being lost past the piston, if not check its the valve train. gook luck.
Old Jul 24, 2009 | 01:56 PM
1931jamesw's Avatar
1931jamesw
uh oh....that aint good....
scootertramp
Ironhead
Feb 3, 2010 06:52 AM
jtbredneck351
Ironhead
21
Oct 9, 2009 09:29 AM
AmericanNightmare73
Ironhead
Apr 20, 2009 09:45 PM
RichLo
Ironhead
16
Dec 10, 2008 11:31 AM
straydog13
Ironhead
11
Sep 10, 2008 06:03 PM
