Dyna Beads...WOW!!!
Old Sep 5, 2009 | 02:51 PM
  #31
Brooklyn Devil Dog's Avatar
Brooklyn Devil Dog
I don't think that's an issue at all.
Stopped or at low speeds, the micro-beads will most likely gravitate to the floor of the tire at the 6 o'clock position. As you go faster, centrifugal force will keep them suspended outward against the tire-side of the wheel.
Old Sep 5, 2009 | 02:54 PM
  #32
schwangster's Avatar
schwangster
Good thread. Got a dealer about 5 miles from my place and going to have to get some to try. My 21" front was a b@#$% to balance.
Also will have to get my buddy with his 280 mph Bonneville lakester to try them.
Old Sep 5, 2009 | 03:01 PM
  #33
Brooklyn Devil Dog
I bet he will definitely notice a difference.
Old Sep 5, 2009 | 03:10 PM
  #34
'05Train's Avatar
'05Train
When it comes to keeping pressure in a tire at speed, I'm not comfortable with "not thinking that's an issue". Those beads are going to be bouncing and rolling around the inside of the wheel when starting and stopping, and on every rotation at speed they'll be coming off the inside surface of the tire when their "spot" hits the ground (the contact patch). Over time, you can't tell me that's not going to have an effect on the rubber sealant on the wheel.
Old Sep 5, 2009 | 03:23 PM
  #35
schwangster
Do they work inside tubes? Or just tubeless?
Old Sep 5, 2009 | 03:38 PM
  #36
cHarley's Avatar
cHarley
I think you need to do a bit more study on the effects of centrifugal force.
Old Sep 5, 2009 | 03:42 PM
  #37
cHarley's Avatar
cHarley
They work fine in both.
Again, check this site for more information.
Old Sep 5, 2009 | 03:46 PM
  #38
'05Train's Avatar
'05Train
I'm quite familiar with it. But you're (I assume) aware that when a tire rotates around to the contact patch, it flattens out, which will push them away from the tire. I don't have any calculations as to which force is going to be greater, but at some point the impact of the contact patch is going to exert greater force than the centrifugal force. Is that at 10mph? 40mph? I don't know, and I doubt you do either.
Wanna take a chance with your life and your passenger's?
I don't.
Old Sep 5, 2009 | 04:33 PM
  #39
jimmers1817's Avatar
jimmers1817
Originally Posted by screamn_eagle
WOW!!! great site cHarley....only $15 for (2) 2oz bags incl. the applicator. looks easy enough. i think i'll try it since i have tried everything else to get rid of my frt wheel wobble.
p.s. cHarley, U gonna go in the ride on Sept 12th with us?
I think I read on their site or somewhere else that they do nothing to correct wheel wobble, they're strickly for balancing the wheel.
Old Sep 5, 2009 | 05:28 PM
  #40
DaddyKnuck's Avatar
DaddyKnuck
In tubeless tires I use the same weight of .2 GM airsoft pellets. Works great and sounds like a maracas when you push the bike around. Because of the constant balancing it doesn't matter if you leave the weight on or take it off. Or take it off at a later date. When changing the tire a shop vac helps to vacumn up the little pellets.
According to a truck driver friend they've been using the beads for a long time. The local sport bike guys love them too.
