Will it need a re'map
Old Sep 12, 2009 | 02:15 PM
BIG DAZ's Avatar
BIG DAZ
6th Gear
Default Will it need a re'map
Im considering fitting some Vance & Hinds stubby pipes to my Nightster, will it need a re'map or will it be ok.....Daz
Old Sep 12, 2009 | 02:20 PM
xFreebirdx's Avatar
xFreebirdx
If your only doing pipes it should be fine.
streetglidin's Avatar
streetglidin
no need to remap with just the pipes
Old Sep 12, 2009 | 03:18 PM
oldairboater's Avatar
oldairboater
All stock bikes are too lean from the factory. If you change intake or exhaust ---you change mixture. The new bikes can compensate to a point. Check your plugs with the bike cold. They will give you some information. Anti-seize them and torque to book specs when you reinstall. If the bike runs or the plugs look lean--remap or tune. I would consider a tuner because it is just a matter of time before you do something else.
Old Sep 12, 2009 | 03:20 PM
JWitz's Avatar
JWitz
You should read up on running lean and hot.....I put V&H Bigshots on mine and then had it on the DYNO.....dropped the gas mileage a bit......but who cares....bike runs cooler and better.....riding two up in the mountains was easy money.....it runs great...
Old Sep 12, 2009 | 03:21 PM
JWitz's Avatar
JWitz
...should have added they are 49 state legal since they don't meet California EPA standards.....don't care about that either.....
Old Sep 12, 2009 | 06:33 PM
BIG DAZ's Avatar
BIG DAZ
6th Gear
Talking
Thanks for the reply's guys, .....Daz
Afishinado
General Topics/Tech Tips
Mar 8, 2014 05:01 PM
beefcake.
Screamin Eagle CVO Models
Jul 3, 2012 12:15 PM
BYEOFCR
Mar 17, 2011 02:35 AM
moresky
Jul 14, 2008 01:14 PM
Errk08
May 11, 2008 08:37 PM
