PCV 0% throttle position?
Old Oct 3, 2009 | 03:35 PM
1potter1's Avatar
1potter1
Default PCV values in first column?
Ive recently installed a PCV with se/ac and rinehart true duals. Exhaust is tight, just wonder how high I can go with the number in the first column throttle position to stop the popping. Im already up to 25 between 1750-6500 and just about got rid of most of the pop on decel. Im interested in keeping a economical map and just wondering high I can go with this number.
Old Oct 3, 2009 | 03:54 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
When i installed my PCV from fuel moto i had decel popping. Then i call Fuel Moto and they told me to 0% out my throttle position which i did and the decel popping went away. Maybe you should zero out throttle position and you may have same results as me.
Old Oct 3, 2009 | 04:09 PM
1potter1's Avatar
1potter1
Talked to the guys at fuelmoto friday and we did 0 out the throttle position and upgraded the firmware, my map started at 0 values in the first column, under his recommendation I tested the values going from positive to negative. Ive found increasing the values has decreased the decel. Just wondering how high I should go before it has a negative effect on the system.
Old Oct 3, 2009 | 04:36 PM
BLKnCHRME09Deluxe
Man i only had a 2 in the throttle postion and i had decel popping. Then entered 0 and it went away. So i do know that such a little adjustment is significant. If i remember correctly(as it was 6 months ago) the guy at fuel moto told me up to 15 ...maybe you should give them a ring since they are the professionels. The guy told me if it kept doing it adjust it then ride...adjust then ride...but for me 0 was perfect.
danzio
Sep 3, 2012 09:43 AM
widerglider2012
Jun 12, 2012 07:39 PM
RPS1981
Apr 1, 2012 06:58 AM
Watch Guy
Exhaust System Topics
May 29, 2011 03:34 AM
Eric in chicago
May 12, 2009 02:07 PM
