Don't mean to be insensitive but theres so much info in here if we just learn to use the search feature.
I've found that feature to be a really good friend and helper.
You can purchase the rear facia for an '09 street glide and it will look very sharp on the RG. I think I paid less than $125 for a color matched facia plus the tri-bar running light that goes in it from Zanotti's online.
Search for a post that I started and you can locate some photos of the rear fender/facia.
The HD filler strips aren't designed to work with the stock saddle bag supports. There are no bolt holes for the top of the filler strips to bolt to. With that being said, I used the bottom bolt to hold them in place and zip tied the top of the filler strip to the saddle bag support. I have had them on the bike for about 3K miles now with no problems.
I went to the shop today and ordered the rear fender facia Thanks For the info I think will have the 103 kit installed also that is one reason I dont like to go there always spend too much $$$$$$$$$$$
