I want to rake my Road King
Old Nov 12, 2009 | 01:33 AM
JustDave71's Avatar
JustDave71
Originally Posted by ciq01
damn that looks sick, but don't the tourers have a short front trail already, so using trees might be skin for it?
Old Nov 12, 2009 | 01:36 AM
qtrracer's Avatar
qtrracer
Long trail 6plus
Old Nov 12, 2009 | 01:40 AM
ciq01's Avatar
ciq01
long trail? what is that?
Old Nov 12, 2009 | 01:45 AM
JustDave71's Avatar
JustDave71
he was responding to my question about the trail on these bikes. I was mistaken and thought it was shorter.
Old Nov 12, 2009 | 01:51 AM
ciq01's Avatar
ciq01
right, but what is the definition of a trail? ive never heard the term used before.
Old Nov 12, 2009 | 04:04 AM
FastHarley's Avatar
FastHarley
Former Sponsor
I would suggest learning a lot more prior to modifying your motorcycle. Never heard of trail? Put down the torches and step away from the motorcycle.
The newest models have changed to an even longer trail to make handling even more lazy 26° / 6.69 in. The diagram below is for an earlier year which was new at the time.
My advice to the OP is seek professional advice prior to proceeding.
Without cutting the frame you can lengthen your seat to handlebar mount. This is 6'-7" on a unmodified frame with excellent handling and far superior ride characteristics than stock.
Old Nov 12, 2009 | 05:07 AM
JustDave71's Avatar
JustDave71
FH I'm a little confused...wouldn't such an upright rake angle lead to a decreased trail measuring with 4-1/2* trees? I thought taht was the proper usage for raked trees was to decrease trail on bikes with higher neck angles?
sorry...sick and can't sleep right now. more than a bit foggy.
Old Nov 12, 2009 | 05:50 AM
Pure's Avatar
Pure
6'2 and you are having image issues?
At 6'7 I hear what you are saying... Check these out:
http://www.ssinisterchoppers.com/choppers/index.asp
http://www.grcustoms.com/shop/produc...roducts_id=651
Old Nov 12, 2009 | 06:07 AM
pococj's Avatar
pococj
Normally, you're correct; raked trees on raked frames is used to decrease trail, and raked trees on a stock frame can often result in too little trail for stability. However, the key on the HD tourers is that the neck post is in front of the fork tubes, rather than behind like "normal" bikes. That allows a steep angle and longer than normal trail. It's also why one hears of the tourers occasionally doing the high speed wobble more often than the other bike lines, and is probably due to something getting slightly out of adjustment/worn.
Old Nov 12, 2009 | 02:23 PM
TideRKC's Avatar
TideRKC
http://www.baggernation.com/products-rakeit.htm
"What we provide is a really nice set of HHI triple trees and an outline telling you everything you’ll need to know to set your bike up right!
Yes there is cutting, chopping, wiring, cussing, and expense involved! If it was cheap and easy... everybody would do it!"
