Need some expertice
Old Dec 3, 2009 | 07:35 AM
pnshvl68's Avatar
pnshvl68
6th Gear
Default Need some expertice
Good morning every one. I just put together my 1968 flh and now I have a mysterious oil leak comming from one of the studs that holds the jugs to the case. Any thoughts on that? I'd really appreciate some feed back.
Old Dec 3, 2009 | 07:52 AM
RHPAW's Avatar
RHPAW
Base gasket? I got Cometics in mine. James is also good.
Beyond that, check a schematic to see if there is an oil passage under that stud (I don't remember), you may need to re-seat it.
Old Dec 3, 2009 | 07:54 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Good advice..
__________________
www.Captain-Itch.com
Old Dec 3, 2009 | 07:58 AM
Nightking's Avatar
Nightking
More than likely the base gasket is leaking. Just make sure you have everything tight.
Old Dec 3, 2009 | 08:43 AM
pnshvl68's Avatar
pnshvl68
6th Gear
I kinda thought an oil passage may be the problem. As far as the gasket kit I used it was a cometic kit.
Old Dec 3, 2009 | 08:53 AM
xFreebirdx's Avatar
xFreebirdx
Did you use a torque wrench when you buttoned it up?
Old Dec 3, 2009 | 08:57 AM
pnshvl68's Avatar
pnshvl68
6th Gear
Have you ever tried to put jugs on a 1968 PanShovel? No room for a torque wrench or even a box end wrench. I had to custom make (ground down a box end wrench) a wrench to even fit the nuts. Too close to the jugs.
Old Dec 3, 2009 | 09:09 AM
IronAss's Avatar
IronAss
Get a "crows foot" put in on the torque wrench at a 90 degree angle and you will get an accurate reading.
Old Dec 3, 2009 | 09:36 AM
pnshvl68's Avatar
pnshvl68
6th Gear
If I do get a crows foot what should the torque be?
Old Dec 3, 2009 | 09:43 AM
IronAss's Avatar
IronAss
Been awhile since I worked on one....don't trust my memory but I'll bet you can find it here.
http://en.allexperts.com/q/Motorcycl...ead-gasket.htm
