88 vs 96
Old Dec 13, 2009 | 11:07 AM
ThreatLevel Midnight's Avatar
Default 88 vs 96
Anybody got experience with each of these engines? (Preferably on the same model, but okay if not...) How do they compare? Performance, mpg, sound, etc., etc., any other points to note?
Gracias,
TLM
Old Dec 13, 2009 | 11:15 AM
oct1949's Avatar
oct1949
really they are close, the 8ci's dont make that much difference...till U get rid of the epa stuff. sound the same or close, mph +-1-2 from42.
88's have the tensioners that need replaced where they fixed that on the 96's
Six gear is nice after U stg1 and cam her.....worthless before on heavier bikes and 2up
Old Dec 13, 2009 | 11:48 AM
BCSG's Avatar
BCSG
A done up 96" is better than a stock 96". I say that because I went from a stock 88" to a done up 95" and I beat my buddies with their stock 96's no problem. I just wish I had the dough to go to a well built 103" or 110". If you want to make the jump but stay stock, 103" is the way to go.
Old Dec 13, 2009 | 12:07 PM
texas_speed_freak's Avatar
texas_speed_freak
I like the 96's simply because you start out with a bigger engine and a 6 speed tranny. Now, with that being said the stock 96's are a pretty poor performer and they run hotter than the 88's. As stated above an 88 punched out to 95 will tear a stock 96 a new hole. The good thing is that once you do the big bore on the 96 and get 103 cubes out of it with some gear driven cams you will be able to outrun most 95's without a problem.
If you get a 96 and dont plan on doing performance upgrades or even if you do the first thing to put on it is a Power Commander to richen up the A/F ratio. That will help with the hotter running engine
Old Dec 13, 2009 | 12:57 PM
SpyderTB's Avatar
SpyderTB
One other thing that makes a big difference in my eyes is the drive ratio is beefed up on the 96. I will look in my tech books to find the numbers but i know for a fact that they are different. And anybody who understands about Primary, Trans, and Final drive ratios will know that they can make a big difference when it comes to launch and top end.
Old Dec 13, 2009 | 01:28 PM
harleydavis's Avatar
harleydavis
Originally Posted by oct1949
really they are close, the 8ci's dont make that much difference...till U get rid of the epa stull. sound the same or close, mph +-1-2 from42.
+1........very nice summary of the difference between the two motors. Just remember that the additional length of the stroke on the flywheel on the 96" helps generate a little more engine heat.
Old Dec 13, 2009 | 01:54 PM
sharkey's Avatar
sharkey
I've got an '01 FXDXT that WAS an 88; wife has an '08 FXDL that's been "stage one'd". I found the 96 smoother and quieter than an 88; a bit better torque, too. Having said that, my 88 is now a 103 and there is no comparison for power, economy or smoothness. My 103 is of course stronger, but her 96 is way more civilized in every other way. I think she used 6th gear across Montana this summer on the way to Sturgis...other than that we don't find it usefull.
Old Dec 14, 2009 | 08:32 AM
bulldogmoe7's Avatar
bulldogmoe7
had '07 road king with the 96 6 speed and now have an '05 electra glide with the 88. i wouldnt trade my 05 for another '07 for anything. i feel there is better take off torque on the 88 than there was on the 96. but i do miss the 6 speed.
Old Dec 14, 2009 | 09:12 AM
cadman311's Avatar
cadman311
It's only 7 horsepower more.
Old Dec 14, 2009 | 10:37 AM
atrox88's Avatar
atrox88
have had both on FLHT's, one an '05 88" and the other an '07 96". All things being equal, I much prefer the 96" even though the 07 is not geared properly (66 tooth rear sprocket). Plus with a big bore kit you're at a 103!!
