I have noticed many recommendations for different types of boots on this forum and most have pretty good reviews and advice.
I have always worn cowboy boots while riding - is there any reason I should switch to some of the heavier soled boots you all recommend?
You will need a more agressive tread pattern for stability, ankle support, and more "bite". Check out the products offered by Bates. Notably their sidezip lineup or something along the same lines from another manufacturer. Tougher than a three dollar steak and meaner than an a one eyed Badger.
If you have always worn cowboy boots & they work why change? As long as they have good soles that don't slip they should be fine. There are always reasons to wear something else but if it works for you why bother.
Any riding boot I look at has to have comfort, stability and safety.
Comfort = I can wear them all day and not hurt
Stability = little flex in the toe, heal and lower ankle area
Safety = no flying laces, low heal, and souls that are meant to grip under most conditions.
i have a pair of redwing loggers that double as motorcycle boots. they work well they're not insulated or waterproof but i've never had any issues i wear them all winter with wool socks and i'm fine. i hate insulated and waterproof boots they don't breathe and are unbearable to wear for long periods. they do have the vibram sole which grabs the road in any condition, they're also steel toe. they are expensive but you'll wear them a decade or more so they're worth it IMO.
but honestly i usually just ride in whatever happens to be on my feet at the time, sometimes my loggers, sometimes chuck taylors, sometimes, docs, even calvin klein work shoes...
