Temperature controlled environment??
Old Jan 9, 2010 | 04:16 AM
Lindsey141's Avatar
Lindsey141
Default Temperature controlled environment??
I have 3 bikes parked in my garage and it's very, very cold out there.
I have a couple of battery tenders that I swap around so they all keep a charge.
Would there be any advantage of heating the garage with a space heater just to keep things "above freezing temperatures"?
Any advantage that would be worth the added expense to my electrical bill?
You hear of bikes that have always been kept in temp controlled environments like there is some benifit to this but I had a few bikes that did well for years without problems (other than the battery issues).
And I'm also sure that a low humidity is also benificial.
But what benefit would just heating "above freezing" have and would it be worth the expense?
Old Jan 9, 2010 | 05:19 AM
cowboy Harry's Avatar
cowboy Harry
I wouldnt worry about it. My garage is cold. I do leave the lights on just to knock some chill off. If you do heat it you may want to put some door seals on. Is your garage attached to your house??
Old Jan 9, 2010 | 07:19 AM
jimmers1817's Avatar
jimmers1817
To keep bikes warm? Silly and a waste of money imo. I'm going to install an overhead heater in my attached garage this year and I like the idea of keeping the garage at a comfortable temp to walk out into during the winter chill.
But I know of no way to effectively seal/insulate the garage door so I'll probably just turn it on when I'm working out there. Currently use a kerosene tube heater but @ $4.60 a gallon that gets expensive.
Old Jan 9, 2010 | 07:21 AM
Kumite's Avatar
Kumite
No need to heat the garage in my opinion. Battery tender alone is sufficient
But to each his own.
R. Todd
Old Jan 9, 2010 | 07:31 AM
kwas's Avatar
kwas
I would say that a problem would occur if it was kept "just over freezing". At this temp condensation forms on the bike causing rust and pitting. I would think it would be safer for it to be below freezing vs just above.
Old Jan 9, 2010 | 07:37 AM
santajim's Avatar
santajim
There isn't anything in that bike that can get hurt by being cold except the Battery. Cover it with a breathable cover,put a battery tender on it, fuel stabilizer and you should be good to go.
Old Jan 9, 2010 | 01:59 PM
flhxkiller's Avatar
flhxkiller
I wouldn't bother with heat. I just run a fan for a few days in the spring when it begins to warm up to keep the moisture down in the garage.
Old Jan 9, 2010 | 02:06 PM
will2002's Avatar
will2002
Your "babies" will be fine Papa. Let them sleep. ............. I've got a couple "on ice" as well.
Old Jan 9, 2010 | 02:12 PM
DannyZ71's Avatar
DannyZ71
Unless you keep it at a steady temp 24/7, forget it. Condensation will be your worst enemy, as someone else has already stated.
Old Jan 9, 2010 | 03:32 PM
WWECOUGAR's Avatar
WWECOUGAR
If you have money to burn go heat the garage. Won't make any real difference though.
