Temperature controlled environment??
Old Jan 9, 2010 | 03:40 PM
nevil's Avatar
nevil
No different than my water cooled John Deere that I've kept in an unheated garage for about 15 winters so far. I keep them both covered and hooked to battery tenders. I even have a '91 911 that won't fit in the garage and it's lived outside for 10 years, under a cover with a tender. No problems from the cold as far as I can tell. Unless you count cabin fever.
Old Jan 9, 2010 | 04:12 PM
rkrdr2's Avatar
rkrdr2
This is the 6th Chicago winter with nothing more than a battery tender for my RK.I don't cover it either...no problems at all...chrome still looks new...The worst thing people do is to start their bikes up and let them idle every now and then...your better off just leaving her hibernate until you can actually get her out on the road!
Old Jan 9, 2010 | 05:26 PM
teedubya's Avatar
teedubya
I keep my bikes in the workshop at 50 degrees all winter. Cub 1550 with snowblower also. I've been told that cold or warm it doesn't hurt as long it stays one way or the other. Where the problems are created is when the temps go from from below freezing to above and back and forth. Condensation is created with this scenerio. Also had someone tell me the chrome takes a beating in freezing temps. but I don't see that. I keep battery tenders on all my equipment when not being used on a daily basis. Before had had my little worshop and just cold storage I would do a full charge on the batteries and bring them in the house.
Old Jan 9, 2010 | 06:21 PM
dog155's Avatar
dog155
Heat is not required just another Tender to save you the hassle.My bikes have always been parked in an unheated garage away from any source of sunlight.
Old Jan 9, 2010 | 08:25 PM
fat_tony's Avatar
fat_tony
Originally Posted by Lindsey141
I have 3 bikes parked in my garage and it's very, very cold out there.
I have a couple of battery tenders that I swap around so they all keep a charge.
Would there be any advantage of heating the garage with a space heater just to keep things "above freezing temperatures"?
Any advantage that would be worth the added expense to my electrical bill?
You hear of bikes that have always been kept in temp controlled environments like there is some benifit to this but I had a few bikes that did well for years without problems (other than the battery issues).
And I'm also sure that a low humidity is also benificial.
But what benefit would just heating "above freezing" have and would it be worth the expense?
Your bikes will stay fresh and crisp longer if you keep the temp. below freezing. Actually there is no humidity below freezing and thus no rust. The only thing to do during storage is to check the battery 1-2 over the winter and charge if necessary.
Old Jan 9, 2010 | 10:04 PM
1skrewsloose's Avatar
1skrewsloose
When I here of questions like this, my response is, what did they do before heated garages? Hell, throw a towel over the seat to keep the frost off and ride.
Old Jan 9, 2010 | 10:44 PM
lh4x4's Avatar
lh4x4
I park my vehicles in a climate controlled garage. It is set at 72 summer and 65 winter. Both conditions keep the humidity down but no exact control.
How much it helps I don't know. I know the battery tenders and StaBil contribute to a trouble free experience.
The conditions make it better for my wife and I though. No cold cars in the winter and no hot cars in the summer.
I have a Reznor garage door that is R-13 rated. Many garage door manufacturers make insulated garage doors. The two man doors into the garage are also insulated.
Old Jan 9, 2010 | 10:47 PM
wolfie1961's Avatar
wolfie1961
I would think that it may be worse. The garage would warm overnight. Then you would open the garage door and let the cold weather in when you leave for work. Garage would warm throughout the day, then door opens and cools. I would think that the extreme temps would be worse on any of the rubber parts.
Just my opinion as I'm not an expert in thermodynamics.
coupe55's Avatar
coupe55
Default Whistle & Bells
Unless you own an ultra Classic or limited, one of the Harley with all the electronics on them I would not worry about it. The new fly by wire throttles and all the electonic gadget's may not fair so well in condensation. I don't heat the whole garage but have a battery tender on my Tri Glide plus a tarp with a heat lamp under it.
The 03 Standard just gets the tender and ain't a bit jealous!
katanaplanet
Aug 2, 2017 04:00 PM
Mchad
Jan 23, 2017 08:25 AM
NH_Tim
Dec 1, 2014 03:07 PM
NightTrain4Al
Nov 11, 2010 04:54 AM
SportyPig
Jan 17, 2009 09:11 AM
