Battery tender ??
Old Feb 2, 2010 | 12:09 PM
HarleyCanada's Avatar
HarleyCanada
Plug it in, and pray for winter to end...............thats my process!
fester1's Avatar
fester1
Originally Posted by acoolmf
I personally use a shumacher charger. Never had any problems with my battery. The H.D. people advise using a deltran charger, but it has a protection circuit that does not allow charging if the battery is below 4.5vdc. In that case, you would have to throw it on a variable rate charger to get the batt up to 4.5 before you can use the deltran. You make the choice.
The Deltran manual indicates 3 volts as the minimum, not 4.5. And 3 would pretty much be a dead battery.
But then, that's probably why theyre called Tenders and not chargers.
Old Feb 2, 2010 | 02:06 PM
lh4x4's Avatar
lh4x4
Rule of thumb is 1.5 amp max for a cycle battery tender.
Old Feb 2, 2010 | 02:21 PM
DGDyna's Avatar
DGDyna
Originally Posted by Lindsey141
if it has a maintainer/floating feature you can leave it plugged in.
I also have the schumacher 1.5 maintainer....always leave it plugged in...never a problem
+1 It charges when it needs to and reduces the amperage for tending
Old Feb 2, 2010 | 03:01 PM
fixedmlc's Avatar
fixedmlc
I thought you all had Schumacher watching over your motorcycles, and was wondering how much he charges to do this.
kzoo
Apr 30, 2012 09:05 AM
Harley_Charley
Electrical/Lighting/Alarm
Mar 11, 2010 10:19 PM
TxDeuce
Nov 27, 2009 08:19 AM
im
Nov 26, 2008 08:00 PM
nutmagnet
Jul 7, 2008 07:23 PM
