Trickle Charger, How Long
Old Mar 11, 2010 | 03:41 PM
Harley_Charley's Avatar
Harley_Charley
Default Battery Tender, How Long Can It Be Left On
All,
POST EDITED TO REFLECT BATTERY TENDER, NOT TRICKLE CHARGER. I was mistaken in thinking I had a trickle charger when in fact it's a Battery Tender.
My bike has been sitting a few months without running. About a month ago I tried to start it up and it took a couple mins but eventually turned over but.......yes there is a but. It would only stay running as long as the headlights weren't on.
So I have a HD Battery Tender hooked to it but how long does it need to be on before the battery will come back to life? It's illuminated flashing green right now....which seems to be fine and represent 80% or greater battery capacity.
Any help is appreciated.
Old Mar 11, 2010 | 04:00 PM
Sammi's Avatar
Sammi
Sounds like you're charging with Battery Tender, not a Trickle Charger.
Not to say the Tender won't do the job, but it won't restore a full charge to a dead battery (or so my Indy Mechanic told me).
Best bet would be to connect battery to a Trickle Charger and use the Battery Tender to maintain the charge.
Sammi
Old Mar 11, 2010 | 04:18 PM
hoethree's Avatar
hoethree
Depending on the age of the battery you may or may not be able to bring it back to life. Is the battery a fully self-contained or one you need to add water to it?
My 1999 FXR2 came stock with a battery that you had to add water to it occassionally. I got rid of it the first time it went dead and replaced with a self-contained battery. That battery lasted me for almost 10 years by keeping it hooked to a Battery Tender whenever it sat in the garage. I just recently replaced it with a new battery and keep it on the Battery Tender 24 x 7 when not riding (obviously).
Old Mar 11, 2010 | 05:05 PM
Harley_Charley
Sammi
Correct you are......my mistake. Anyway, how does a Battery Tender work and how long can it stay connected or is it indefinite?
Got the motorcycle started up this evening, same routine. Motorcycle would run as long as the headlights stayed off. Took it for a 30 min ride around the neighborhood and decided to test the headlights again......this time the bike didn't shut off (that's a good thing). They stayed on for the remainder of the ride will no ill effects.
I put it back on the battery tender and the light code shows now that the battery is more than 80% capacity.
Can anyone educate me on how a battery tender works please.
Old Mar 11, 2010 | 10:19 PM
imskier2's Avatar
imskier2
Go to the Battery Tender site and it is all explained there.
http://www.batterytender.com/
Look under Technical Info and then
  1. Float / Maintenance Charging: Is it really necessary?
This wil help you understand Why.
Wally1212!
Dec 4, 2017 07:11 AM
zyban
Sep 16, 2016 11:09 PM
19JMan70
Nov 7, 2013 03:13 PM
TxDeuce
Nov 27, 2009 08:19 AM
alfalfa
Mar 13, 2009 03:55 PM
