Where would you start?
Old Feb 2, 2010 | 05:23 PM
carlgrover's Avatar
carlgrover
You can get a factory service and a parts manual on ebay on CD. Get them immediately. Ask all questions down in the ironhead forum on this website. Lots of knowledge down there.
As others said, change ALL fluids. Don't forget the front master cylinder. I would rebuild the carb completely. It should be a Zenith; very easy to do. Pull the tank out and clean it thoroughly. It is going to be full of rust. Replace the gas line, pull the petcock and replace it too. Having done all this, the fuel system will be pretty much clean and "shouldn't" give any problems.
Pull the plugs and pour a little oil in the cylinders. Put the bike on a stand and cycle it gently into 4th gear then rotate the rear wheel to move the pistons and get things going. Obviously, you will also need a battery, air filter, plugs, points, condensor, etc.
After all of the above is done and you have looked over the service manual, look up the procedure to adjust the pushrods and do it. It is a regular maintenance item and not hard to do.
Tires are your call as to whether you can do them yourself or not but when the wheels come off, repack or replace the wheel bearings!
When you get the thing first started and running, be gentle with the transmission. Don't try and force it into gear. I would expect the clutch to vibrate and be real sticky. If it's true to form it will jump into gear and die the first time you try to ride it. You will find out what else is wrong after riding it.
Read that service manual! It is your first line of defense for problems. Congratulations on entering the wonderful world of ironhead Harleys. I nearly bought a 74 back in the day but it had been already sold. That right foot shift might feel a little funky but you'll learn to love it i'm sure.
Old Feb 2, 2010 | 06:48 PM
dog155's Avatar
dog155
It should turn over unless the pistons are stuck,(depends on how and where it was stored)Do a compression test.The carb will probably need serious attention.Pull the fuel shutoff out of tank,to clean it.Change all the fluids,finally a new set of plugs,give her a go!
Old Feb 2, 2010 | 07:01 PM
cdestuck's Avatar
cdestuck
Ya can start by givin us some pics, lots of them, do a albul during the restore, we're sure to love them!!
Old Feb 2, 2010 | 07:13 PM
bayshorecs's Avatar
bayshorecs
4th Gear
I will certainly post some pics as soon as I can. I hope to try and get it home this weekend. It is only about 5 miles away but I will need to lay it down on a trailer and drive SLOW to get it home.
I know the tank is still off since he painted it about 5 years ago so i shouldn't have to worry about rust too much.
I guess I need to get a manual first and make some room in the garage.
Any ideas on the speedo cable on why he would have removed it? i guess I need to move this to the ironhead forum...
Old Feb 2, 2010 | 07:15 PM
Juve996's Avatar
Juve996
Originally Posted by piasspj
Put some MMO (Marvel Mystery Oil) in the cylinders. Leave it sit a couple days. Remove the plugs and turn it over (by hand) a few times. Repeat several times.
You gotta love that MMO, best thing ever. Works well in fuel systems too.
Old Feb 3, 2010 | 02:43 PM
softail04's Avatar
softail04
I know all you guys are right but the first thing I wnt to do when I get something is see what I actually have and try to make the engine start or at least try just so see if I have a dead player or something that can be made to run fairley easy. so I would attack it with carb cleaner and a lot of kicking after I see if has spark and oil..
Old Feb 3, 2010 | 10:23 PM
Tonup's Avatar
Tonup
It is a real thrill to put back an old bike in order. I remember working on my Norton for months. It didn't run for years, I put the bike in pieces. Motor (top and bottom), transmission, steering, everything.
Once its all cleaned, oiled and put back together, time for the first start...
It fired up after 2 kicks, the feeling you get to ear it running is unbelivable.
Old Feb 3, 2010 | 11:06 PM
oct1949's Avatar
oct1949
I had one of those that didn't run 3 years one summer......
Yep back in 72 I dropped a valve in the rear jug with <3k on her... after I had her redone she didn't do too bad,, just wouldn't come close to a cb750, in those days...
still lots of good times with her..
I tore her down to the frame, chopped, polished/chromed, hog rear tire, 6 over tubes and repainted her while the motor was being done..
Good luck on the build up...
Old Feb 4, 2010 | 08:09 AM
softail04's Avatar
softail04
this 76 sits in my garage
Attached Thumbnails Where would you start?-sporty-1.jpg   Where would you start?-sporty.jpg
Old Feb 4, 2010 | 08:18 AM
xFreebirdx's Avatar
xFreebirdx
LOL its funny that in the pic your right leg looks bigger than the left. lol
