Speedometer accuracy
Old Feb 20, 2010 | 09:57 PM
ashmarc's Avatar
ashmarc
Originally Posted by WWECOUGAR
Changing tire size seems like it would be more of a factor.
I've wondered about this......here's my understanding for cages and bikes....
Changing tire sizes will alter your speedo if your speedo is calculated from the wheels.....
.......but if it is calculated from the transmission (I've heard some vehicles do this, I had a '76 Vette that had this set up IIRC) it doesn't matter the wheel size...
Anybody else heard of this?
Old Feb 21, 2010 | 12:25 AM
MidnitEvil's Avatar
MidnitEvil
I know when I have gotten pulled over, the speed the cop claims I was doing seems about the same as what I saw when I looked at the speedo right after noticing the cop.
Old Feb 21, 2010 | 04:50 AM
PPBART's Avatar
PPBART
So you're saying that if you're running 15" wheels or 16" wheels, the Vette's speed at a set RPM would be the same? I don't think so...
Old Feb 21, 2010 | 05:00 AM
CroK's Avatar
CroK
I think maybe ashmarc may have gotten that backwards. On the older cars with speedo gears at the tranny, we would have to change out the gear at the tranny to compensate for the change in tire size. Revolutions at the wheel hub would remain the same no matter the size of the tire, I believe? Kinda confuses me at that point. Larger wheels move more ground at the contact point, and the reverse would be true for smaller wheels, same revolutions at the hub...
Sorta seems to me that wheel size would affect either?
Old Feb 21, 2010 | 11:06 AM
krusty1's Avatar
krusty1
Tire diameter will indeed affect either (larger diameter than the engineered design anticipated means less rpm's carry you further with each revolution....you'd be traveling faster than the speedo indicated). In a practical sense tire wear and the relatively small differences in tire diameter for a given size are insignificant....and most vehicles are quite limited in what you can squeeze into a wheel well or fender space.
Of course none of this really means anything. It's a rare day when I am running less than 5 mph over the posted limit, and I've blown by hundreds of cops with radar over the past 40 years, and never been ticketed for that kind of minor excess velocity....when I've been popped it's been for more like 20 to 30 mph over the limit.
Old Feb 21, 2010 | 11:19 AM
Morris9982's Avatar
Morris9982
Actually wheel diameter does not directly affect the accuracy of a speedometer.
What affects it is the circumference of the tire. If you change wheel size on a car (what they used to call going +1 or +2) and change the tire to a lower profile (going from a 70 to a 60 or a 45 to a 35), the circumference could stay the same.
If the circumference of the tire changes (the distance around the tire or the distance it rolls to make one complete revolution) then the accuracy of the speedometer will change.
I've compared my car and bike to the roadside speed checks and they are both fairly close. One thing to keep in mind is the speed you see on the display may or may not be the speed of your vehicle. It could be displaying the speed of another vehicle. Only way to be sure it's yours is if you're the only one on the road.
Old Feb 21, 2010 | 12:22 PM
bord3r's Avatar
bord3r
Well the cop that got me last night said mine must be broken because 65 is not acceptable in a 45..........
Old Feb 21, 2010 | 01:36 PM
ashmarc's Avatar
ashmarc
As with many things in life.
Old Feb 21, 2010 | 02:02 PM
OldFenderGuy's Avatar
OldFenderGuy
I've had a Deputy Sheriff I know check a number of our bikes to get a better idea of how accurate the speedometers were on various Harleys.
He used certified radar on some, and 'pacing' with a certified speedometer on others.
On average the Harley's read about 5% slow, which means that a 50 MPH reading was actually a verified speed of around 48 MPH, a 100 MPH reading was an actual speed of 95 MPH, etc..
None of them were 'dead on', and none of them read lower than the actual speed that was clocked on radar.
That's not bad, as most 'metric bikes' checked were off by up to 10%.
Old Feb 21, 2010 | 03:33 PM
scoteh's Avatar
scoteh
When in doubt, I just get on the Interstate, set the tripmeter to zero at a mileage marker, then run ten miles. You want it more accurate, run 100 miles.
