ABS light flashing
Old Feb 21, 2010 | 06:45 PM
wulffman's Avatar
wulffman
Stage IV
Default ABS light flashing
Hello, any one have experience with the abs light flashing when the bike is running? Any suggestions where to start?
Old Feb 21, 2010 | 07:01 PM
izzy's Avatar
izzy
mine blinks anytime i'm at less than about 20 mph.
Old Feb 21, 2010 | 07:38 PM
RKKY's Avatar
RKKY
abs light is supposed blink up until 15-20mph then should stop. If it keeps blinking after 20 then there is a problem.
Old Feb 21, 2010 | 09:17 PM
Intrepid175's Avatar
Intrepid175
Originally Posted by izzy
mine blinks anytime I'm at less than about 20 mph.
That's wrong. It should blink when you first start the bike. As RKKY said, once you've passed about 15 mph, it should be off. Actually, mine usually goes off by the time I hit the end of the driveway and I'm no where near 15 mph at that point. Anyway, once it goes out, it should stay off unless something goes wrong with the system. If it's coming back on at any time after that, you need to get it looked at. If the light is on or flashing, the ABS is "not" functioning!
Ride Safe,
Steve R.
Old Feb 21, 2010 | 10:29 PM
Robert_W's Avatar
Robert_W
I thought it was at 3 mph the light would stop blinking.
Bob.
Old Feb 21, 2010 | 11:00 PM
clicker01's Avatar
clicker01
I don't have abs, but check the easy stuff first. Fluid level, bleed, and connections.
Old Feb 22, 2010 | 11:24 AM
Intrepid175
Bob.
That's in line with what my bike is doing. As I said before, mine is off by the time I reach the end of the driveway. If RKKY's is staying on a little longer than that, I wouldn't worry about it as long as it's consistent. Either way, the point is that once the light goes off, it shouldn't come back on again. If it does, there's a problem with the system and it needs to be checked.
FWIW!
Ride Safe,
Steve R.
Old Feb 22, 2010 | 07:14 PM
SUPRPIG's Avatar
SUPRPIG
"When in doubt... whup it out!" The owners manual... that is, mine says it flashes until your speed exceeds 3 MPH after initial start up. If it is continuous it detects ABS is malfunctioning. It will also illuminate to indicate the presence of diagnostic trouble codes (i.e. see a dealer).
Old Feb 22, 2010 | 07:18 PM
flhxkiller's Avatar
flhxkiller
check for trouble codes if you can. If it's fairly new you can get them yourself using the speedo..
b2000s81
2014-2024 Touring Models
Sep 28, 2018 06:58 AM
sixgun95
Oct 22, 2014 01:28 PM
baldguy13
May 13, 2014 09:38 AM
Just Me
Mar 4, 2012 08:02 PM
tda69
Feb 26, 2009 01:58 PM
