Narrow beach bar and riser ?
Old Mar 18, 2010 | 05:35 PM
ljrock88's Avatar
ljrock88
Default Narrow beach bar and riser ?
I am trying to use the below set up, but as you can see from the picture part of the knurl is showing. Even if I turn the top part of the riser around then the knurl shows on the other side. I have heard this is the set up on a 2005 CVO Fatboy (not sure if that is correct) and should work.
part #56857-05 Narrow Beach Bar
part #56851-04 Riser Kit
Does anyone know why this is happening?
Old Mar 18, 2010 | 05:41 PM
schumacher's Avatar
schumacher
you're gonna have to go with a 1 piece handlebar clamp
Old Mar 18, 2010 | 05:44 PM
schumacher's Avatar
schumacher
Old Mar 18, 2010 | 05:53 PM
ljrock88's Avatar
ljrock88
The bars are 1 1/4. I assume that clamp is for a 1 inch handlebar?
I haven't been able to find any 1 1/4 inch risers that would fit with a clamp like that or any clamps that are 1 1/4 inches.
Old Mar 18, 2010 | 06:05 PM
creatv1's Avatar
creatv1
I have a 1-piece clamp on mine, but since it's sort of a tapered "V" shape, a little bit of the knurl shows. Wild1 has a clamp with squared sides that will cover all of it. Are your bars 1 1/4 all the way? Most of those have smaller diameter grip locations and clamping area.
http://www.wild1inc.com/accessories.html
Old Mar 18, 2010 | 06:24 PM
ljrock88's Avatar
ljrock88
Yeah they are 1 1/4 all he way; accept for where the controls are.
cajunlowrider
Jul 17, 2017 04:07 PM
CHEE-Z
Nov 8, 2013 08:28 PM
ICIBUY
Mar 1, 2012 09:26 AM
jgarrett0103
May 24, 2009 09:58 PM
Fireslayer
Mar 10, 2009 03:36 PM
