How much good does a new A/C really do?
Old Mar 22, 2010 | 06:45 PM
MNPGRider's Avatar
MNPGRider
American Iron, in the last two issues, installed a Screaming Eagle air cleaner last month, and this month, installed pipes, on a Sportster. Both articles had before and after torque and hp charts.
Study them carefully...... there was virtually no gain below 3,000 RPM for either modification, which is typically the result no matter what air cleaner or pipe change you make. In many cases, there is actually a loss of power. The stock units perform perfectly in the normal riding range....the gains are only at high rpm, or, as Joe Minton calls it, "Bar Stool Hp."
But when you need to pass that semi, going uphill, and crank on the RPM's, you'll be glad you made the change.
Old Mar 22, 2010 | 08:07 PM
plutnicki's Avatar
plutnicki
As I recall, neither of those two mods that AIM did included a tuner. In the Sportster article (May 2010), they specifically state that they believe that the 02 sensor bikes will recalibrate themselves (i.e. keep the bike lean).
Old Mar 22, 2010 | 08:11 PM
ashmarc's Avatar
ashmarc
Originally Posted by FastHoss
All pipes and air cleaner do is add alot more noise
Really?
Kuminatcha
Screamin Eagle CVO Models
Apr 24, 2013 07:16 AM
Sp0rtster
Feb 25, 2010 08:39 PM
Failz
Feb 19, 2010 03:52 PM
bull346
Dec 31, 2008 01:18 PM
WillieD
Dec 18, 2008 09:13 PM
