I've read many times here on the HD Forum that Dynas will outhandle Softails. Why is this? Is this attributable to differences in rake and trail? Rear suspension? And how noticable is the difference?
I appreciate any info.
i think the rear shocks play a major role. the further out the socks are from the center of mass the more stable it should be. now im not a scientist and have no way to test or prove this hypothesis.
Dyna V. Softail Two different Motors with two different power ranges. The engine are mounted in the different ways. The dyna are oversize sportsters and there are different racks with each of the Dynas. The softail has the counterbalanced motor with a rigid mount to the frame. The dyna is a rubber mounted motor without the counterbalanced make your feel different with more power and faster RPM's.
Thank you, very much......stated that in onother thread an' got slammed....all d'pends on what ya want,I guess they got their niche......
Dyna out handles the Softail
Dyna out accelerates the softail
Softail out farkles the dyna
Softail is the "typical" HD, which is part of why they cost more.
Two different machines for two different circumstances. Use to salivate over softails, now have a dyna. Next bike will be a Touring bike added as the softail would serve no purpose for me.
Dyna's does feel more stable when zig zagging back and forth. However a Softail with aftermarket Progressive 422's on the back make a world of difference on a Softail. The stock Softail is a smoother ride over a stock Dyna. If you ride them both I will say you will chose the Softail if price is not a factor. Just my .02.
Less unsprung weight (the weight NOT supported by the suspension) the better anything will handle; the softail swingarm is about 100lbs+, the dyna swingarm is about 20lbs. There's sound reasoning behind putting an aluminum swingarm on the XR1200; it's expected to handle well. The difference may or may not be noticable depending on your riding style.
01 FXDXT
607lbs with 1/2 tank of gas
aluminum rims and swingarm
composite rotors
handles OK
The swingarm on the Dyna and Tour bikes are bolted to the trans. The Softail is bolted to the frame. I like with the dyna you can make a U-turn anywhere and the softails have to do a threepoint turn.
