Yeah, interesting... never seen this style lift sold by them before! I will have to check this one out... got to see what the lift capability is. I would think it would lift a bagger just fine.
1100 lbs.cap.comes with straps,supposed to tie down to lift legs,think i,m gonna put eyes on lower support legs that are on the ground and tie down after raising.seems it would be more stable to me.as it is it is as stable as the conventional floor lift i have,which has a little wobble when wrenching.i like it cause it's open on the bottom allowing access to softail shocks.
after installing the lowering kit i couldn't get the other lift under the bike without putting a 2x6 under the back tire.this one slides right under.that, access to the shocks,and height are all good points,however one side of the bike IS a lttle limited on access on some things but not real bad.it's like everything else,good points,bad points,nothing in this world is perfect......except the riding day i had yesterday
