screaming eagle air filter question
Old Apr 24, 2010 | 01:13 PM
yandeltx's Avatar
yandeltx
Default screaming eagle air filter question
I have a screaming eagle air filter on my 04 lowrider (carb) and I but the outside edge off to expose the filter, it turned out great. By doing this it exposes the two bolts that hold the backing plate on and they look like some kind of black, almost hard plastic looking, fasteners. Does anyone know what size bolt I would need to replace them. I would like to find two chrome hex type bolts to use since they can now be seen.
Thanks for your time.
Old Apr 24, 2010 | 04:39 PM
KevinMcC's Avatar
KevinMcC
Take one of them out, see what nut you have will thread on. Take that nut to the store and see what bolt will fit into it, that's size bolt you need.
Old Apr 24, 2010 | 04:49 PM
Softy 103's Avatar
Softy 103
I think those are your rocker box breathers and if they are you don't want to put a common bolt in there because you will be blocking your breather vents
Old Apr 24, 2010 | 06:58 PM
95custmz's Avatar
95custmz
Take a bolt out and examine it.If it is hollow, it is indeed your breather bolt.
Old Apr 24, 2010 | 09:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you take out the breather bolts you will soon be writing the forum about some oil being blown out your engine seals. You could install an oil collection system or keep your stock oil vapor return system, one or the other, the engine needs some relief.
Old Apr 25, 2010 | 07:34 AM
yandeltx's Avatar
yandeltx
thanks to those that replied. looks like something I better just leave alone. no need in creating a nightmare. thanks again,
johnnyhumble
Apr 22, 2012 01:02 AM
JohnFromBrooklyn
Nov 25, 2011 03:15 PM
SportyAnne
General Topics/Tech Tips
Sep 2, 2011 08:44 PM
1948doc
Exhaust System Topics
Apr 20, 2008 04:19 PM
Guz
Jan 23, 2008 05:15 PM
