Need help with control cable swap.
1) To change the brake cable Do I have to empty out the brake oil thats in the reservoir before removing the old cable ? Do you take out the caliper and then remove the bleeder valve? or can I change the cable and then bleed the brakes ? I just dont know what happens when you remove the brake cable from the lever does it drip all the brake oil ?
2) To change the Throttle and Idle cable do you have to remove the Air filter ? I have the tank already off the bike.
Any pics you have about swapping cables would be appreciated. I did a search in the forum and all it says is get a manual but manual has a process for bleeding brakes not a specific process of how to replace any of the control cables ... Thank you guys
Step two: Attach all lines leaving bleeder valve open... then fill reservoir with fresh fluid. When fresh fluid reaches bleeder valve, slowly close valve and while tapping on brake line build up fluid behind it. When fluid stops passing into line from reservoir, stop with the fluid and look for air bubbles coming up out of line into reservoir... wait until bubbles stop completely then top off reservoir and put gasket and top back on. Should be good to go!
The cables are basic... watch what your doing when you take the originals off and reverse the steps to put the new ones on... take a picture before you start if your worried. You shouldn't have to remove the air intake if you can get to the cables with your tank off.
