Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Steel Braided Brake Cable Install
Old Nov 6, 2005 | 01:27 PM
WarriorHD's Avatar
WarriorHD
Default Steel Braided Brake Cable Install
I'm considering asking Santa to bring me some nice steel braided brake cables for Christmas this year. Before I ask for them, I was wondering how hard they are to change out? I plan on doing front and rear and it doesn't look all that hard but I want to be sure I can do it myself. Can someone tell me what the process is to do it? Do the brakes need to be bled? Any gotcha's that I should know about? I checked for instructions in the DIY area of the site but couldn't find anything on replacing brake cables. Any input would be a huge help! Thanks!
Old Nov 11, 2005 | 01:41 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Steel Braided Brake Cable Install
its really not a problem, you should try to find a shop that sells the lines and get part numbers of everything you need, some of the fittings may need to be 90 degree and some may need to be a different angle. when your done they will need to be bled. good luck!
Old Jan 19, 2006 | 03:04 AM
wlbowers's Avatar
wlbowers
When you change the lines you have to remove all of the fluid. You will have to bleed the system throughly after you change the lines. All air has to be out of the system.
DO NOT USE THE OLD FLUID
Make sure you use the correct fluid type that was in the system.
Old Apr 8, 2006 | 02:43 AM
Crewchief88's Avatar
Crewchief88
6th Gear
I have done this lots of times before. You have to drain the fluid from the lines. Then it is just a matter of changing them out. Bleeding is the most important thing to do. Before you bleed them be sure to check all the lines to make sure that the fitings are all tight. It is real easy to do the job. I also suggest to go to HDBikeparts.com. They sell cables a lot cheaper and if you say what kind of bike you have and what mods you did to the bike then they will send the right stuff. Fittings and all. Myself and a few friends use that online store a lot. I happen to be the local wrench in my neighborhood and have found that website to be real good.
Old Apr 10, 2006 | 04:58 PM
warthog's Avatar
warthog
Cover anything on the bike that could possible get brake fluid spilled on it, it will eat into the finish. I've used tin foil in the past as it's easy to shape to cover almost any part.
SJK01
Dec 17, 2017 04:38 PM
grancuda
Feb 28, 2016 08:42 AM
sp9997
Apr 25, 2010 09:19 AM
mrcrazynutz
Apr 22, 2010 11:59 AM
Gunshow
Jan 15, 2008 10:43 AM
