Compensator Bolt Loose
I find that cleaning, using locktite and having all my friends and neighbors come over and stand on the cheater bar..... then jump up-n-down will torque it sufficiently....I think. I have had mine fixed on almost every long trip I have been on by mechanics that said..."that's it....it is tight now....it ain't going anywhere...I promise" only to have it work loose again.
I had to replace my stator this last time and I had a 45 AMP kit installed which is thicker. Maybe I'll be okay now, but I do have a trailer-hitch ball wrench in my tool kit and my primary chain locking tool as well. One end of it will fit my comp nut if I have to fix it in the middle of nowhere again. I am not paying some idiot at a dealership over $100 a pop to play with it.
They hold the final drive pulley nut with a retainer plate. I can't see why they have never came-up with a similar retention system for the comp nut, but they would rather issue service bulletins on how to tighten it and make money off of you to have it tightened.
Thank god these are not airplanes!
Has any one here done that and if so how bad is it when putting it in gear or hitting the throttle?
Maybe somebody that has eliminated the compensator will chime-in here and make some comments.
lots of owners went ahead and had the SE comp installed because of the hard knock on start up also.
SERVICE BULLETIN
M-1170 May 27, 2005
COMPENSATING SPROCKET TORQUE PROCEDURE
Ž
Purpose
This Bulletin documents a torque and turn-of-nut procedure
for tightening the engine compensating sprocket. This procedure
improves the clamp load on this assembly and replaces
the present tighten-to-torque procedure.
Motorcycles Affected
All 2003 through 2005 Touring, Softail, and Dyna model
motorcycles including CVO models with Twin-Cam engines.
Production vehicles began using this procedure May, 2005.
Dealer Action
Update all service literature and notify service technicians. To
assure this procedure is used, insert this Service Bulletin
number in the TORQUE VALUES tables in Section 6.1 SPECIFICATIONS
of the Service Manuals covering Touring, Softail
and Dyna models for model years 2003 through 2005.
Instructions
1. See Figure 1. Before installing the clutch, primary chain,
compensating sprocket and shaft extension assembly do
the following:
a. Clean threads on engine sprocket shaft (1) and
internal threads in sprocket nut (2) with LOCTITE
7649 CLEANER/PRIMER, Part No. 98968-99.
NOTE
If a new sprocket nut, with lock-patch, is being installed the
clean/prime of the internal threads is not needed. If the nut is
being reused, clean the internal threads as specified in step
a. above
b. Apply two drops of LOCTITE THREADLOCKER 262
(red) to the threads on the engine sprocket shaft.
c. Apply engine oil to the complete underside (3) of
sprocket nut (2). This is the area that will contact the
sprocket cover.
2. Follow the Service Manual procedure for installing the
clutch, primary chain, compensating sprocket and shaft
extension as an assembly.
3. Install sprocket shaft nut and hand tighten. Follow the
Service Manual procedure for installing the clutch hub
mainshaft nut.
4. See Figure 2. Tighten sprocket shaft nut to 75 ft-lbs
(101.7 Nm).
Figure 1. Compensating Sprocket Preassembly
Figure 2. Tightening To 75 ft-lbs (101.7 Nm)
1 2
1. Engine sprocket shaft threads
2. Sprocket shaft nut
3. Underside of nut
s0645x.
7857a.
IMPORTANT NOTE
In the interest of preserving customer safety and satisfaction, always check for outstanding recalls whenever any motorcycle is brought into your
dealership for either maintenance or service.
Š2005 HARLEY-DAVIDSONŽ MOTOR COMPANY
M-1170 2 of 2
5. See Figure 3. Scribe a line (3) on the sprocket shaft nut
(1). Continue the line on the sprocket cover (2) as shown.
6. Tighten the sprocket shaft nut an additional 45° to 50°
(50° MAXIMUM).
Any thing made has its problems. Lambo owners had several model years that the roofs had bad leaks. Even Rolls Royce needs parts and techs to keep things going.
Every heard of a parts failure for a Boeing plane or a Caterpillar tractor? You bet there have been.
Get over it. Have it fixed. Yes it is irritating if the tech does not do a good job of the repair, but again that is what happens when it is humans making things.
125,000 deaths per year from mistakes in the medical profession and you are bent out of shape for a minor repair.
Now...as far as the procedure posted by DLI...the next time any of you have a comp nut re-torqued....look to see if you can find any scribed lines. It's just another overlooked service bulletin and it has been out for years.
