Trailer Question
Take the curb weight of the bike and estimate the center point. With that point just over the lead axle, move it a little less than half of the distance between the center point and the the lead axle.
Get a scale and weigh the tongue weight which should come in at 10% of the load and trailer weight.
This is very important. If the weight is too far to the rear the trailer will sway as you tow. It will get worse if you go down hill.
Too far forward and the trailer and tow vehicle will pogo up and down more than normal.
I have set up trailers for decades and have had good luck with them.
I always recommend trailer brakes and equalizer hitches for dual axle trailers.
Here's my set up for a dual axle trailer.
Even with cross winds and semi's passing this holds the trailer straight.
Then you can make your ignorant comments about trailers.
