Crank sensor replacement mileag/age.
Old May 12, 2010 | 03:25 PM
azharleyrider86401's Avatar
azharleyrider86401
Question Crank sensor replacement mileag/age.
Looking to see out of the people who have had to change one what kind of miles/time do you have on your bike. Bike farted once and since then have code 41 for ckp sensor. I am about 28K right now. Don't wanna be stranded.
Old May 12, 2010 | 04:57 PM
smitty901's Avatar
smitty901
07 RG 15,000 replace intermittent failure. Do not know if I damaged it changing oil of if it was defective HD covered under warranty 45K on it now no more problems with it.
Old May 12, 2010 | 05:22 PM
cHarley's Avatar
cHarley
I'm on my 4th (POS) CKP sensor in 60,000 miles.
Old May 12, 2010 | 05:37 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
There is a root cause to that failure and it is not the sensor. That many failures/replacements are statistically impossible. I would consult a different dealer for an opinion or find out which supplier makes the sensor and call their engineering department. They will know. However, if you get oil on it that can cause failure as well.
Old May 12, 2010 | 05:38 PM
Lincoln33's Avatar
Lincoln33
That's a new CKP every fifteen thousand miles, not cool. I have an 04 Sporty Custom I picked up used with only 3300 miles I hope I don't have the same luck.
How difficult is it to replace and what's the general cost?
Old May 12, 2010 | 05:51 PM
cHarley's Avatar
cHarley
It's easy to replace, about 10 minutes once you've done one, but expect to pay about $50.00 for the sensor. And yes, it's a common and recurring problem on 04up Sporties.
Old May 12, 2010 | 05:56 PM
cHarley's Avatar
cHarley
I don't need to consult anyone else, multiple Sporty forums have mile long threads on the issue. The sensors $uck and the only source is HD. Since the sensor mounts into the primary case, getting oil on it is a given.
BTW, I turn my own wrenches.
Old May 12, 2010 | 08:15 PM
Neckball's Avatar
Neckball
My son rides a 2004 XL1200C and he's on his third sensor with less than 30,000 miles. Previous post about Sportys having a sensor problem is well documented except with the dealer network. All too often they don't run the DTC's and diagnose the trouble as carb related.
Edit- 75,000+ miles on the original sensor in my Road King.
Old May 12, 2010 | 08:16 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
50k miles and it has never been replaced.
Old May 12, 2010 | 08:23 PM
kkiley's Avatar
kkiley
2000 Fat Boy with 43,000 miles on it. Failed 3 weeks ago, just wouldn't start. One of my many issues I've had lately...put a new battery in Mar 3rd, rode it yesterday, 0 volts and replaced...
