volts
Old May 31, 2010 | 08:12 AM
flvff's Avatar
flvff
Stage II
Default volts
when driving down the freeway at about 70mph my volts jump up to 14+ and my engine light will come on. this happens for about a mile or two. this is on 1996 ultra classic
Old May 31, 2010 | 09:27 AM
the blob's Avatar
the blob
id ck voltage regulator.
Old May 31, 2010 | 11:04 AM
95custmz's Avatar
95custmz
+1 on voltage regulator.To test regulator,turn ignition switch in off position.Connect an ammeter between the battery pos. terminal and the regulator.The reading should not exceed 3 milliamps. If the amp reading is excessive the regulator/rectifier is damaged and must be replaced.
vicsponjr
Sep 15, 2019 06:24 PM
Florida Swamp Yankee
Jun 4, 2012 09:43 PM
spgtti
Mar 11, 2012 09:45 PM
ewhinger
Sep 19, 2010 06:51 PM
