How do I handle this problem???
I'll make a long story short...
While getting ready for Sturgis I found that my clutch was bone dry.
I had the dealership perform the 1000 mile service at around 1200 miles.
I found the dry clutch at around 4000 miles.
The bike does not leak (parked in garage on clean concrete), and a quart of oil doesn't just evaporate.
Therefore, I believe the tech forgot to fill.
How much damage has already been done?
How will this effect the warranty?
How should I approach the dealer/service manager?
What response should I expect from the dealer?
I've waited to post this/deal with the dealer until I was no longer pissed.
Don't want to rant or bitch...just looking for some good advice. TIA
If the dealer values your loyalty
as a customer, they'll at least check it for no charge and should fix it for free if they're up front about their mistake. If they find no damage, get it in writing just in case the clutch takes an early crap. It's also important to keep cool, no one likes being confronted by a loud, obnoxious customer demanding to have things done, polite at first is always a better approach.Let us know how you make out.
D'
Anyhow, I ended up replacing the chain and the shoe. The chain was wayyyyyy stretched and the shoe was little plastic bits in the bottom of the primary. The clutch, compensator and stator were probably worn more than they should have been, but I did not experience any issues with them.
I agree with TCBurke, your clutch pack isn't the only thing to be concerned about, the chain, tensioner and clutch packs, and maybe even the seal/seals in there should be checked out.
You did say bone dry, I read you post, but did you remove the plug with a pan underneath to check for sure? If it is really bone dry and you rode that many miles I would suspect the clutch is warped from heat and worn badly. I would agree with the gentleman that talked about the chain and adjuster wear also.
I hope its just a very low oil level and not completely bone dry. It sucks that you have to check it by removing a cover and then you have to replace the gasket. Damn gaskets cost a bundle also.
Follow up with us about the dealer reaction and result.
I think the issue will be the mileage.
As for "bone dry"...it took a full quart. I didn't remove the drain plug. I was just topping off.
The clutch performed fine, and still does. No smoke, noise, grabbing, etc.
The dealer has been decent in the past, and I hope that continues.
I'll stop by and talk to them Monday (with a cool head).
I'll post back with results.
