Octane? Really?
Old Jun 16, 2010 | 07:17 PM
faber's Avatar
faber
Originally Posted by will2002
Maybe it was a BP station, and they had a little too much water in their gasoline.
Good one, Will
Originally Posted by wideglidebob
bad gas i run 91 or 92 and have had to run 89 when on a trip, and thats all they had never had any problems, my son is cheap and runs the cheapest gas they have i think 85 or so and bike runs great so go figure
I've run lower octane at times. Always seems fine, but got a little knocking with the 85.5.
Originally Posted by lh4x4
Run the lowest octane that your motor will tolerate. If you are not accellerating hard and don't lug the motor 87 octane will do fine. It fires easier and gives more mpg.
Many confuse octane with power. The octane rating is only to indicate the resistance to igniting and all octanes yield the same power.
Yeah, I know the higher octane is for higher compression. The higher compression can produce more power, but not the gas itself.
I was wondering if going up in octane could have thrown the ECU off so much that I got that rough idle and stalling.
Bad gas makes more sense, though. The place is call Kum-n-Go, after all.
Old Jun 16, 2010 | 07:38 PM
Donnylee's Avatar
Donnylee
Eggzactly!
Old Jun 16, 2010 | 09:33 PM
Panthers65's Avatar
Panthers65
Yup, the higher the octane, the LESS combustible the gas is. You can always run higher octane (within reason) because the spark plug will ignite the fuel anyways. Lower octane in a higher compression engine will ignite the gas early because it's literally compressed to a point where the molecules heat up and ignite.
the higher power comes from the higher compression. The same amount air and gas compressed into a smaller area and then ignited will yield higher energy.
Old Jun 16, 2010 | 09:36 PM
MNPGRider's Avatar
MNPGRider
Gotta disagree with your first paragraph. Whether or not your bike seems to run fine is totally dependent on the engine management system adjusting for detonation. As soon as the knock sensors detect detonation, your spark will be retarded to prevent detonation. If you are not running at full advance, you are losing power and gas mileage. There is only so much it can do, however, and if it's already retarded your spark due to the low octane, and you get into a lugging or high heat situation, you may have used up your engine's ability to compensate, and detonation will occur.
Run what your manual tells you, which is a minimum of 91 octane.
Old Jun 16, 2010 | 09:37 PM
Tucson_Tim's Avatar
Tucson_Tim
I always run 91 octane. Not sure if it matters or not but the price difference for such a small amount, I just figure "what the heck, why not?". I used to try and fill up at a "premium" station but in the last several years I just fill up anywhere.
Old Jun 16, 2010 | 10:06 PM
MikeyTX's Avatar
MikeyTX
Sorry but, it recommends 91 octane. My '09 Road Glide runs quit nicely on 87 octane.
Old Jun 16, 2010 | 10:13 PM
ranger56528's Avatar
ranger56528
I run 89 in both bikes(01 is carbed and 06 FI) with no problems so I dont see a need to change.....Even new cars/pickups recomend 87 due to the ECM's,heck even new boat motors recomend 87 oct.....
Old Jun 16, 2010 | 10:24 PM
94nostalgia151's Avatar
94nostalgia151
maybe a dumb question but is your bike carburated and are you still at low alltitude?
all gas is the same, only the additive is different.
Old Jun 16, 2010 | 11:43 PM
R-Jay's Avatar
R-Jay
What % of the gas was Ethenol? That stuff attracts water and if its an old batch that was in their ground tanks for awhile, it probably sucked some up. With all the rain (and snow!) that you have had lately, that could be the problem.
Old Jun 17, 2010 | 12:23 AM
Zenmervolt's Avatar
Zenmervolt
With EFI it will run just fine on lower octane because the knock sensing will retard timing and run the mixture richer to compensate and prevent damage if it starts knocking. Both actions reduce power.
On a hot day or with a heavy load EFI will pull back and you won't be getting rated power from your engine. It will run OK and it will not suffer damage, but do realise that the engine won't be making full power.
