Octane? Really?
Old Jun 16, 2010 | 05:07 PM
faber's Avatar
faber
Default Octane? Really?
Kind of a dumb question, and I think I know the answer, but I'd like to hear your thoughts.
So, here in Montana, we're at altitude. Not crazy high like Colorado, but high enough, I guess, that gas sold here is not at the normal sea level octanes (87, 89, 93) but the high-altitude versions (85.5, 88, 91). I'm told that is to compensate for the thinner air. So I always put in 91 octane in my bike. Always runs fine.
But I was at a gas station where they had the sea-level octanes. So I thought, 'Heck, I'll try the 93.'
Every since then, my bike has been idling ROUGH, especially when cold. And it will even stall at idle. Have to give it more throttle than normal when letting the clutch out, too.
I know octane is all about the timing and compression, but could it have that much difference?
Old Jun 16, 2010 | 05:16 PM
paguy's Avatar
paguy
Just a thought. Maybe not the octane. Sounds like you got water in the gas.
Old Jun 16, 2010 | 05:27 PM
Foodog's Avatar
Foodog
I'm gonna go with paguy and wager you got some bad gas. A bit higher octane rating shouldn't affect an engine this way.
Old Jun 16, 2010 | 05:29 PM
mentor70's Avatar
mentor70
I have run 91 all the time, but when i run Shell my bike runs like ***.
bike should have run the same or better.
Old Jun 16, 2010 | 05:52 PM
faber's Avatar
faber
Bad gas!
dang it.
I think you guys are right. Makes sense.
Old Jun 16, 2010 | 06:11 PM
will2002's Avatar
will2002
Maybe it was a BP station, and they had a little too much water in their gasoline.
Old Jun 16, 2010 | 06:25 PM
wideglidebob's Avatar
wideglidebob
bad gas i run 91 or 92 and have had to run 89 when on a trip, and thats all they had never had any problems, my son is cheap and runs the cheapest gas they have i think 85 or so and bike runs great so go figure
Old Jun 16, 2010 | 06:31 PM
lh4x4's Avatar
lh4x4
Run the lowest octane that your motor will tolerate. If you are not accellerating hard and don't lug the motor 87 octane will do fine. It fires easier and gives more mpg.
Many confuse octane with power. The octane rating is only to indicate the resistance to igniting and all octanes yield the same power.
Old Jun 16, 2010 | 06:43 PM
dedjr67's Avatar
dedjr67
Did you ride down to sea level or trailer the bike? Is your bike fuel injected? The reason I ask is I had a customer tow there car from Colorado to Florida when they unloaded it from the the trailer car would not run because the computer was still thinking it was at 5000 ft in thin air took some time to relearn fuel ratios but if driven would have learned on the fly so to speak.
Old Jun 16, 2010 | 07:05 PM
faber's Avatar
faber
No, just a chain I normally don't go to on the other side of town (Kum -n- Go......yes, it is a gas station).
