Heli Coil Tang
Old Jun 18, 2010 | 11:38 AM
fonemann's Avatar
fonemann
Default Heli Coil Tang
Im re-threading my head for a new crankcase breather bolt to hold on my Big Sucker A/C the instructions tell you to break off the tang after you get the Heli coil in place.Just where does the "tang about a 1/8 inch piece of coil" go after its off. Will it interfere with anything mechanical in the head????
Paranoid at this time.
Old Jun 18, 2010 | 11:41 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Make sure it does not fall into the head.
Old Jun 18, 2010 | 11:47 AM
bigstevex4's Avatar
bigstevex4
Grab it with a pair of needle nose it will twist right off. Then pull it out!
Old Jun 18, 2010 | 11:57 AM
Grammaton's Avatar
Grammaton
Do this.
The tang is already scored so it comes off easily.
Old Jun 18, 2010 | 01:41 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by dr. V-twin
make sure it does not fall into the head.
oh yeah.....lol :d
Old Jun 18, 2010 | 02:38 PM
RoadKingRon1's Avatar
RoadKingRon1
If the hole is too small for needle nose, I use a pick similar to a dental pick. Get behind the tang with the pick and pull it toward you. Should snap right off.
It also helps to have a small but strong magnet.
Old Jun 18, 2010 | 03:35 PM
fonemann's Avatar
fonemann
I have really small needle nose pliers, Good Idea with magnet, But the coils are stainless steel!
RidemyEVO
EVO
11
Jun 8, 2011 03:03 AM
TexasBikeBoy
EVO
May 24, 2011 10:08 PM
jgc 89
Electrical/Lighting/Alarm
Oct 5, 2010 06:59 PM
jizquie560@aol.com
Aug 12, 2009 02:19 PM
grippper293
May 8, 2007 06:12 PM
