Help STARTER PROBLEM
Old Jul 8, 2010 | 02:17 PM
AnniversaryFatboy's Avatar
AnniversaryFatboy
Default Help STARTER PROBLEM
My battery died on my Fatboy about 3 days ago and ever since then my starter has done nothing but whine. I am able to push it off but when I hit 'start' it just whines. Would a new battery fix this?
Old Jul 8, 2010 | 02:24 PM
carpetride's Avatar
carpetride
I'd say if the bike can be jump started with cables, the battery isn't holding a charge and needs to be replaced.
Old Jul 8, 2010 | 02:35 PM
AnniversaryFatboy
Yea I tried that as well. Starter just made that spinning noise. I have just never had any problems out of the starter before and then this battery thing (which was my fault, left the dang switch on) happened and all of a sudden starter just spins. I also put the battery on a trickle charge for a couple of hours and nothing, same spinning sounds. Thanks for your reply.
Old Jul 8, 2010 | 02:36 PM
SG 1's Avatar
SG 1
If the starter was working before my guess would be yes.
Old Jul 8, 2010 | 02:40 PM
AnniversaryFatboy
Well Im trying a battery today after I go to the Stealership to get one. 116.99 was around the same price as AutoZone and Sears
Old Jul 8, 2010 | 02:42 PM
AnniversaryFatboy
and nice GLIDE. Got mine for sale and as soon as it goes, Im grabbing me a street glide. Thanks for the reply
Old Jul 8, 2010 | 02:59 PM
SG 1's Avatar
SG 1
If that is the original battery its probably time for a new one anyway. I think your better off with the OEM battery than one from Sears or Autozone. You might try charging over night with say 6 amps, but if thats an 03 like I'm guessing and original, then the battery is likely toast.
I left the radio playing on mine all night one time. Luckily it was new enough to charge and bring it back. I've had a tender on it ever since.
Old Jul 8, 2010 | 03:12 PM
RHPAW's Avatar
RHPAW
If you hear the starter spinning, but the engine isn't turning over, the starter clutch is not engaging. A new battery won't help that. You may need a new starter clutch.
That job is a pain on a softail because with the oil tank, you have limited space to work. I think mine is getting ready to go soon too. Good luck to us.
Old Jul 8, 2010 | 03:40 PM
soft 02's Avatar
soft 02
+1 on the starter clutch. I'm on my 3rd. and its an 07
Old Jul 8, 2010 | 05:45 PM
99octane's Avatar
99octane
Definitely.
Get a new battery.
BUT
Before installing it, verify WHY the old one died.
It was just old?
Is the regulator regulating?
Is the alternator alternating?
With engine at idle you should have about 14 dot something Volts at the battery leads.
Less than 12.8-13 volts, and your battery won't get recharged properly.
More than say 14.5-14.6 and you risk ruining it.
Current is also relevant, but testing for current requires proper equipment and procedures, so don't try it unless you are familiar with the procedure and its caveats (or you don't mind frying the occasional multimeter).
I don't understand exactly what you mean with "whine"? Does the engine turn properly and easy, or it just does a sound like it's trying to run but it hasn't got enough juice?
If the starter runs properly, but the doesn't engage the flywheel, then you have a mechanical problem.
Bagger99
General Topics/Tech Tips
11
Oct 7, 2013 10:17 AM
mbierbac
Nov 2, 2012 09:41 PM
radio915
20
Apr 15, 2011 08:58 PM
Beauregard
May 22, 2009 03:22 PM
1badshovel1
Shovelhead
Mar 16, 2009 11:31 AM
