Buyer Beware!!
Old Jul 22, 2010 | 03:52 PM
Geoff's Avatar
Geoff
I would have asked a dealer tech the question.
Abbinc83's Avatar
Abbinc83
Originally Posted by inaroush
Sounds Just like the scammin liars from American Classic Motors in Zieglerville, PA....
Sorry you had a bad experience.
I was just wondering what kinda of bad deal you had with american classic motors? I just ordered a new set of wheels from them haven't even gotten them yet
Old Jul 22, 2010 | 04:07 PM
Gonzy's Avatar
Gonzy
Gonzy
Originally Posted by Phrogman
Umm, you bought a 21" wheel from a Night Train which has a Wide Glide front end with 41mm fork tubes. You wanted to put it on a Sportster with a Narrow Glide front end with 39mm fork tubes. There is no way it would fit without any modifications whatsoever. In fact, I'd be willing to bet you won't find any 21" wheel which will fit a Narrow Glide front end.
You said it, Buyer Beware. It's the responsibility of the buyer to know what he's buying, not the seller to know what the buyer needs.
Just my 2 cents.
As to the wheel, we are replacing a 21 inch wheel that has been bent, this is not a modification from a different size wheel.
True, but when you ask the seller point blank, "Will it fit with no modifications?' and they answer "yes" then the onus is on the seller. They either answer truthfully with good knowledge of the item or state that they don't know. Either way, yes, I should have checked with a parts tech, etc. Lesson learned.
Old Jul 22, 2010 | 04:26 PM
kevmic28's Avatar
kevmic28
So its been said take the original rim hub and get it laced to the new wheel. Problem solved. Yes there is work involved but not too much considering.
Old Jul 22, 2010 | 04:29 PM
FlamedFXR's Avatar
FlamedFXR
Originally Posted by babalu
you can file a complaint with paypal and get your money back very easily. you'll have to return the wheel and paypal will hold the money from the seller until you can prove delivery.
file a complaint with paypal for item significantly not as described and start the process, it can take a while but you'll get your cash back.
That only works on Ebay ( because Ebay owns Paypal) Different complaint process off-Ebay.
Old Jul 22, 2010 | 04:30 PM
ROMPUS's Avatar
ROMPUS
Sorry about your luck. Hope that pepson gets his
Old Jul 22, 2010 | 05:05 PM
ga guy's Avatar
ga guy
Sell it on ebay, maybe you'll get more money than you paid. Next time do your own research.
Old Jul 22, 2010 | 05:11 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Measure
Your hub is the same as a 2005 Dyna Front Wheel cast 43815-04 WHEEL ASSEMBLY 13-spoke, 19 inch hub width: 4.396”. Both have narrow glide 39 mm forks. The triple tree holes & fork tubes are in the same centers.
If the HDF member that sold you this wheel could have read you the measurement to you prior to the sale than you would know that the hub would/would not fit. Since you have the same hub but bent wheel you could have measured the hub yourself. I doubt that this member sold this wheel/hub to you knowing it is a wrong size for your application.
Old Jul 22, 2010 | 05:16 PM
GeezerDude's Avatar
GeezerDude
I agree with you the seller should not have told you that. However, that's no excuse for the buyer not doing any research at all. You should have been skeptical to start with since the wheel you were buying came off a totally different family line than the bike you were putting it on.
Old Jul 22, 2010 | 05:18 PM
FastHarley's Avatar
FastHarley
Former Sponsor
PS, the hub off of a Softail night train is 6.32" wide, the same as a dresser 2000~current. You did not need to call anyone as I believe you had the answer sitting at your own house. Parts guys usually are fired sales persons from CompUSA anyhow.
