Remapping
Old Aug 1, 2010 | 10:27 PM
Eagle51's Avatar
Eagle51
6th Gear
Default Remapping
Will I need to do a remap, if I only do a stage 1 air cleaner and slip on exhaust?
Old Aug 1, 2010 | 10:32 PM
jeff.georgalas's Avatar
jeff.georgalas
Yes, otherwise you'll be running extremely lean, and they come lean from the factory to begin with. I wouldn't go with a dealer "re-flash" though, as far as I'm concerned they're a waste of money if you do future mods. I'd go with a fuel management system. I personally like the Power Commander, but there are other good ones out there as well.
ChromeJunkie's Avatar
ChromeJunkie
In a word, yes. A power commander or sert or some other type of fuel management will be better. As long as you only change the intake and exhaust, a canned map will most likely give satisfactory results.
Old Aug 1, 2010 | 10:37 PM
SOCALHD's Avatar
SOCALHD
Yes. If you are just doing slip-ons and an A/C you will be fine with a download only. But ideally and SEST to get the best tune
Old Aug 1, 2010 | 11:05 PM
Other Sheep's Avatar
Other Sheep
If you're not going to do motor mods you could get away with an XiED for about a hundred dollars or less if someones selling one in the classifieds here. Nightrider.com
Old Aug 3, 2010 | 10:18 PM
Eagle51's Avatar
Eagle51
6th Gear
Thank You for all the replys and help.
joey883
Feb 10, 2013 09:53 AM
Sloverado
Feb 24, 2012 04:48 PM
usmcdevildog
Jul 11, 2009 06:00 PM
SD Night Train
Mar 19, 2009 05:34 PM
MyClassic09
Sep 12, 2007 10:09 PM
