Change "football" for round cover?
Old Aug 5, 2010 | 07:51 PM
dfndr's Avatar
dfndr
Thanks for the advice. The bike has only 150 miles on it and I don't want to do a stage 1 at this early time. I bought a Harley dipstick oil thermometer and the bike was running at 250 to 275 degrees when not in stop and go city traffic. I want to get it broken in and see if there is a temp problem without any alteration of the factory settings. Scorpion07's explanation above sure makes sense but I'm concerned that the Big Book says you can put on SE slip-ons without mentioning need for ECM recalibration, BUT it clearly says you need recalibration if you change the air filter---and that looks like it means you need it if you change the air filter ONLY. I'm not much of a mechanic so I really appreciate your help.
Old Aug 5, 2010 | 08:56 PM
golfblues's Avatar
golfblues
It will stay around 260 stock. With a PC-V, pipes & filter my 09 runs 245 when it's over 85* & around 230 under 85*. My 06 tops out at 220. And the 06 gets about 5-6 mpg's more then the 09.
Old Aug 6, 2010 | 07:04 AM
Scorpion07's Avatar
Scorpion07
I would think the stock mufflers are quite a bit more restrictive then the stock intake? Guy's on here have modded out their exhausts only, without having to add a fuel management system. I would think the same would be true of the A/C only?
It's possible the book says that, since most people who put the SE A/C on only do it because they already modified their exhaust?
I guess you won't know until you find someone who's done it.
Old Aug 6, 2010 | 11:12 AM
10ring's Avatar
10ring
Originally Posted by Scorpion07
Simple: Your cylinder is capable of as much volume as it can take in through the intake, and push out through the exhaust. Both are limited from the factory (for various reasons) of the cylinder's potential. If you only change the efficiency of one (intake or exhaust) the other will be the limiting factor, and nothing changes. The cylinder can't pull in or push out more then the lesser will allow. No fuel adjustments are necessary.
A Stage I opens both (intake and exhaust), allowing for more air flow through the engine. In order to take advantage of that added airflow more fuel is required, otherwise a lean air/fuel ratio will occur, limiting, and in most cases decreasing, it's power potential. By adding more fuel at this point, you add more fuel burn per stroke, adding extra power capability to the unrestricted engine.
It is my understanding that any remapping that comes from MOCO will always result in a 14.7:1 AFR. This is mandated by the EPA. So, if one increases the airflow and gets a factory download, it will increase the amount of fuel, but only until the increase achieves the same 14.7:1 AFR, which will still be the same ratio that is resulting in a lean condition to begin with. Just more of everything. This might result in more go but will still be too lean.
I assume that aftermarket suppliers such, as Power Commander, do not suffer from the government restrictions on AFR, as they do not produce entire motorcycles.
Old Aug 6, 2010 | 12:09 PM
Scorpion07's Avatar
Scorpion07
My understanding is that most "piggyback" fuel management systems all use the 14.7:1 as the base maximum (some actually swap out the sensors for higher 15+:1 ratios). They circumvent the base ratio by tricking the ECM to believe that regardless of how much fuel is added, the 14.7:1 ratio is the maximum obtained. This occurs even with the new "learning" autotune versions.
This allows the tuner to tune according to engine requirements at any given engine RPM, outside of the leaner EPA mandated ratio.
Old Aug 6, 2010 | 12:17 PM
trip20's Avatar
trip20
Originally Posted by carlo
You can put a stock round set up from a CrossBones.
That is exactly what I did to my Wide Glide. I didn't want to change the air flow from stock as I'm not ready to do the rest of the performance mods.
I just wanted to get rid of the football. A forum member named Taddeoeg made the suggestion, and someone from HDForums sold me their complete Crossbones air cleaner assembly for I think $35 shipped. Here's what it looks like on my bike:
Old Aug 6, 2010 | 02:44 PM
dfndr's Avatar
dfndr
So this is getting very interesting. Does this mean that if I upgrade at the dealer to SE air cleaner/pipes/ and remapping/ECM controller, it's still going to be running 14.7:1 lean? Does that do much for me in anything other than sound improvement? Thanks
Old Aug 6, 2010 | 03:04 PM
golfblues's Avatar
golfblues
That's it! Now add a fuel management device & you're good to go.
Old Aug 6, 2010 | 03:13 PM
10ring's Avatar
10ring
Anything that is HD branded and designed to be used on public roads will always be at 14.7:1 They have to abide by EPA regulations. Scorpion07 stated that some systems are designed to make the stock HD ECM "think" that it is still dishing out the 14.7 ratio, even though some industrious tuner-operator has it cranking whatever (read richer fuel mix) it needs to both cool the engine and to improve performance.
As far as I know, unless one first swaps out the stock exhaust and the A/C, then purchasing a fuel management gizmo will not do much because all the hopes and dreams in the world won't un-restrict the intake and outflow, which is needed to garner much improvement.
Old Aug 6, 2010 | 03:42 PM
Grrrl's Avatar
Grrrl
My boyfriend has a round on his FLHX. He actually just has the cover on and left the filter exposed. Looks great.
My sporty still has the oval one on but I just bought a screaming eagle heavy breather. I am just waiting for the TTS tuner to arrive. Unfortunately I just can't change mine out straight across. Looking forward to giving my knee more clearance.
