help elec. problem
Old Aug 15, 2010 | 04:11 PM
harryr's Avatar
harryr
Stage II
Default help elec. problem
i have a old pan/shovel which is only running on one cycl (front ) i have no spark to the rear i have a new coil new batt. plugs i have checked all my wires etc. anyone have any ideas thanks Harry
Old Aug 15, 2010 | 04:33 PM
32vld's Avatar
32vld
How did you check your plugs and wires?
Did you do a compression test?
Old Aug 15, 2010 | 06:04 PM
harryr's Avatar
harryr
Stage II
yes did both wire are good compressions good it must be a switch or broken wire somewhere but thanks anyother ideas
Old Aug 15, 2010 | 06:12 PM
TwiZted Biker's Avatar
TwiZted Biker
The coil fires both plug wires at the same time , if one is working and the other isn't the problem is "A" the coil , "B" a plug wire or "C" a fouled plug , swap the wires around on the coil with new plugs not re-cleaned ones and see if the problem moves .
CHJ
Shovelhead
Nov 14, 2012 03:29 PM
nproblem
Jun 16, 2010 03:04 AM
nproblem
Jun 13, 2010 04:32 PM
a21m
Mar 31, 2008 07:05 PM
a21m
Mar 14, 2008 08:02 PM
