whats the trick?
Old Sep 4, 2006 | 11:08 PM
TJ461vs's Avatar
TJ461vs
Default whats the trick?
Whats the trick in getting the little clips off of the idle and throttle cables inside the switch housings? And then getting them back on without opening them to the point that they wont seal? Any one got any good advice for these?
Old Sep 4, 2006 | 11:15 PM
liltrk's Avatar
liltrk
Default RE: whats the trick?
Loosen off the slack adjusters under the handle bar. That will give you enough cable to rotate the ends out with a needle nose plier or similar tool. You do not have to open the brass ferrules at all.
Old Sep 4, 2006 | 11:30 PM
SHEP's Avatar
SHEP
Loosen the adjusters and remove the brass ferrules. You do not remove the clips. Simply pull the cable out of the housing. Piece of cake.
Old Sep 4, 2006 | 11:39 PM
TJ461vs's Avatar
TJ461vs
How do you get them back on?
Old Sep 5, 2006 | 02:10 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
LMAO............good question!!
ORIGINAL: TJ461vs
Old Sep 5, 2006 | 04:45 AM
xxxflhrci's Avatar
xxxflhrci
Just give them a good yank. They pop right out with no damage. Then, just push them hard to re-install them.
Old Sep 6, 2006 | 10:14 PM
Wally's Avatar
Wally
I find using a metal pic something like a dentist's tool really help for removal and instal. You hook it around the cable instead of using needle nose.
Old Sep 6, 2006 | 10:19 PM
alazlo's Avatar
alazlo
Most will pull right out with a tug. For the tough ones a flat screwdriver between the cable & housing usually does the trick. They just push back in...
harleyman15801
Dec 1, 2013 10:08 AM
TUCCI
Nov 16, 2013 06:45 AM
cloudenbeck
Nov 16, 2012 03:53 PM
YmeHP
Sep 4, 2009 09:50 AM
firedocs
Oct 15, 2008 02:02 PM
