Remember using my dad's bulk role of igntion wire and grabbing his box of terminal ends and making my own spark plug wires. Still have the spark plug sand blaster that gets the occassional use.
Made handmade gaskets too.
Changed many a car tire, breaking the bead and working the bead off the rim all by hand. Then installing the new tire by hand as well.
Still have my dad's old tire irons.
Matter of fact I have his first snap on tool box from the 40's. I keep most of all his old/antique tools in that box.
I remember a little gizmo I bought that had alligator clips that you could hook to the battery. it came with a small bag of sand you you could stick a plug in it and clean it on the side of the road. Can't remember where I got it but it seems like something that J.C. Whitney would have sold.
Using rope (or twine) to tie luggage (duffle bag or just stuff wrapped in a blanket) to the bike.
Not being concerned with what you (or anyone else) wore.
Walking to get to a phone.
Every time you walked within 50 feet of a motorcycle you could smell gas. That is one of the reasons why I have kept my old Triumph all these years. I still like that smell.
putting lawnmower muffler on the end of expansion chamber held on by springs to hold down the noise around the neighbor hood and then off with it when back at the gravel pits.
tying up your kicker arm after your return spring broke 60 miles from home or using your mousetrap by hand cause your clutch cable snapped!
Push starting my pan cause the Kicker Arm broke in two in the middle of a kick (happened 3 times in the 15 years I had that bike). The last time it happened the jagged edge on the bottom half that was still attached to the shaft cut the **** outa my calf....Those was some good times there fur sure. Yup
Those must be the good old days. I've done the vise grips on the shifter arm after breaking the lever in the middle of nowhere. Had a friend stuff his tire with weeds and bushes to get to the next town once.
While I may not be old, wrenching on Pans and Shovels is a hobby of mine and a lot of these things continue to be the norm for me! I guess I just like to tell my computer-ran, machine-built, electronically-loaded, laser-measured, fuel-injected, air-shock suspensioned, cd-equipped Harley to go to hell every now and then while I ride on of my old bikes. That way I can manually adjust the fuel, manually adjust the timing, manually kickstart the beast, and the only noise I hear is the engine rattling through the pipes! Afterwards I manually clean up a few oil spots, have a beer, and be glad that I don't have to go through all of that EVERY time I want to ride.
