Charging issues
Old Sep 23, 2010 | 07:27 AM
veegee's Avatar
veegee
Default Charging issues
A recent chain of events has led to replacement of the battery, regulator and stator on a 2000 Ultra. Now during idle the volts drop to around 12.0-12.5. When at higher RPM's it goes to just above 14.0, where it was prior to this. Any suggestions...... Thanx
Old Sep 23, 2010 | 07:30 AM
geezer glide 56's Avatar
geezer glide 56
What RPM s does your bike idle at? Your volt meter on your bike might not be accurate check it with another meter to verify what it is reading.
Old Sep 23, 2010 | 07:42 AM
Faast Ed's Avatar
Faast Ed
Sounds pretty normal to me.
Old Oct 3, 2010 | 08:32 AM
veegee's Avatar
veegee
Thanx Geezer & Ed. I appreciate the feedback. Seems that it is normal and i was not aware, unlike cars, bikes aren't constantly charging. I think i got it.... we'll see.
Old Oct 3, 2010 | 12:45 PM
32vld's Avatar
32vld
What were the voltage readings before you started changing parts?
Then you would of had a base line to compare.
Old Oct 3, 2010 | 04:06 PM
dickey's Avatar
dickey
Totally normal, it's charging correctly
Old Oct 3, 2010 | 05:00 PM
cHarley's Avatar
cHarley
+1 - you need around 1500 RPM before your stator will generate more juice than the bike is drawing from the battery. At a "fast" idle you should have 13.5+ volts.
Old Oct 3, 2010 | 05:02 PM
TwiZted Biker's Avatar
TwiZted Biker
Your good , have fun .
BUZZMAN3367
Jun 20, 2024 08:46 PM
scottiej42
Electrical/Lighting/Alarm
Apr 13, 2015 11:17 AM
Maple Leaf Hog
Nov 7, 2011 07:33 AM
jsgilbert2
Mar 10, 2010 05:23 PM
ratleaker
Oct 31, 2008 06:33 AM
