Help - fatbob 2010 - added rush slip ons
Old Sep 23, 2010 | 04:57 PM
fatbob123's Avatar
fatbob123
Default Help - fatbob 2010 - added rush slip ons
Quick question - not looking for more power - just the pure hd sound and the pipes sound great - so I have to get a power commander or is it ok to just get the bike mapped
Old Sep 23, 2010 | 05:00 PM
05RdKing's Avatar
05RdKing
duplicate
Old Sep 23, 2010 | 05:07 PM
05RdKing's Avatar
05RdKing
with only adding the Rush mufflers, you don't have to do a thing, it is fine as is -
Old Sep 23, 2010 | 05:56 PM
fatbob123's Avatar
fatbob123
It is a ecu reg bike
Old Sep 23, 2010 | 08:04 PM
rhj's Avatar
rhj
Default Pipes
What size baffels do you have. My dealer told me if I stayed under 2.25 I didn't have to have any other mods. I had 1.75 on my dyna and it ran great.
Old Sep 24, 2010 | 10:16 AM
FATKEVIN's Avatar
FATKEVIN
I have been running them on my 09 Fatbob for over 3000 miles. After about 200 miles I could see the the black build up on the inside of the pipes and knew that it wasn't running too lean. You can also check the plugs but I have had no problems and like the others said it will be fine. I have the 2.0s and they sound real good.
Old Sep 24, 2010 | 10:28 AM
srshaw's Avatar
srshaw
I think that with the new bikes with the cats, even the 2.25" baffles are ok since the cats increase the back pressure a bit (I might be wrong though). I have the 1.75" and had no probs. If I were buying some more I would probably go with the 2" baffles.
Old Sep 24, 2010 | 12:41 PM
thebarzeen's Avatar
thebarzeen
I have an '09 with a 103, no cat and the 2 1/4 baffles...... a little gurgle on deceleration but no popping..... no remap and no other mods
Old Sep 24, 2010 | 02:06 PM
oct1949's Avatar
oct1949
I 've had my Rush since May of 07. I've talked several times with Rush Techs.
AS posted in here many times, pipes only U don't need to do anything else, but,, U'll still be Stock epa lean on Ur A/F ratio. Wont hurt the motor but will run hotter than if U did a full stg1,
Last time (last fall) I talked to a Rush tech they now recommend to not go over 1 3/4'' to Help a little on low end TQ on a Softtail thats otherwise stock, 2'' if U do stg1 and cams.
Back in 07 they used to say up to 2'' was fine on pipe only change..
U can still go 2'' but may lose 2-3 #'s of TQ under 3k rpm's when compared with the 1 3/4''ers..which really isn't much.
Just IMO on a softail or Dyna I wouldn't go over 2'',, believe me the 2'''s are plenty loud.
Touring bike probably could go bigger since there mufflers are bigger.??? not sure, I'd call Rush to check if I had a bagger.
DenimBlackFLHXS
2014-2024 Touring Models
14
May 20, 2014 01:49 PM
UglyMoFo
Dec 19, 2013 01:13 PM
1HD1C
Jun 9, 2011 02:24 PM
Tony-OH
Sep 24, 2010 05:04 PM
Solitario
May 31, 2008 01:10 PM
