After reading some in the EVO section, I decided to switch out the cam in the EVO. The bike has always ran good and the previous owned has added just about everything you can add to the outside.
When I took it to the local wrench I decided to let him put it on the DYNO for a few adjustments and he came back and told me the cam in place now was not stock. It produces 73.5 HP @ 4500 RPM and 79.2 Ft lb of torque@ between 4000-5200 RPM.
I know there is a ton of knowledge here. How does those numbers compare with a stock EVO or twinkie and what cam do you think it may be?
All thoughts are appreciated. I will also post in the EVO section.
I don't see how your questions can be answered, your dyno numbers are close to meaningless unless the dyno brand, what correction standard (if any), and smoothing factor was used.
