Oberon Levers...
I think ... buy a kit, look very industrial ... I like.
I do not know how they work, but hopefully it will be better than the original levers.
Adjustable Levers
Oberon Performance replacement levers are manufactured to fit and suit Harley Davidson motorcycles. Adjustment is achieved with fingertip control in either adjuster direction. The eight adjustments are either side of position 4 (similar to stock) giving adjustment up to 30mm (1 1/8”) of lever travel. Our unique RADIAL CAMŽ design achieves this extraordinary range with ease. This is mainly due to both the close tolerance design and the high quality roller bearing, around which the cam operates locating each position with a comforting ‘click’. Each lever is despatched fully assembled in the style and colour of your choice ready for use. Oberon Performance supplies a full specification sheet including part numbers with all levers. The cams in the levers have been hard anodised for longevity and reliability, sufficiently lubricated on assembly for smooth adjustment transition.
Also available as an alternative choice are the Oberon Performance ergonomic levers with AIROŽ featured vent, also used on race track by many enthusiasts.
• Oberon RADIAL CAMŽ System
• 8 selectable position settings
• CNC machined from billet aluminium
• Precision roller bearing for smooth action
• 3mm Ball Bearing click guide
• Short Reach setting for easier operation
• OEM anti-rattle shim accommodated
• Simple to install Clutch and Brake Lever
• Stainless steel fasteners
• Original lever position enhanced
• Integrated adjustment stop
• Manufacturer’s warranty
• Lever Blade colours;
Black, Blue, Gold, Red, Silver and Titanium look
• Adjuster Switch colours;
Black, Blue, Gold, Orange, Red, and Silver
• Lever position range up to 30mm
Oberon-performance.co.uk - Harley-Davidson
