Roland sands adjustable levers
Old Apr 11, 2016 | 09:55 AM
103m 95g's Avatar
103m 95g
6th Gear
Default Roland sands adjustable levers
I hope this is the correct area for this.
I am considering some roland sands adjustable levers for a 98 sporty.
I found an old thread where they talked briefly about them but there was no follow up and the thread was from 2012.
Does anyone have them installed? how do you like them?
I just cannot wrap my head around how they work, i.e... when the lever is closest position to the grip is the articulation enough to disengage the clutch the same when its at the full extended position? or does the articulation say the same no matter what position the lever is in?
Thanks in advance
Old Apr 12, 2016 | 07:10 AM
multihdrdr's Avatar
multihdrdr
The Adjustables change the "travel"...just like your thinking. There's more than enough.
Try this...Hold your clutch in, let out until it starts to "grab" (friction zone), now pull back just enough to eliminate the "grabbing" ...where's your lever in relation to your grip?
You probably have room to shorten the "travel"
Can't help with the testimonial though, but someone will
Old Apr 12, 2016 | 12:46 PM
103m 95g's Avatar
103m 95g
6th Gear
Well at $130 for a set, I rolled the dice yesterday. they should be here thursday. Hopefully they are just the ticket for the little woman to be more comfortable.
Old Apr 13, 2016 | 12:12 PM
Next In Line's Avatar
Next In Line
Adjustable levers are very common on sportbikes.
Nothing ground breaking about them.
Bill G
14
Jul 1, 2019 06:45 AM
lee123
Nov 24, 2018 08:34 AM
RSDUDA
Screamin Eagle CVO Models
17
Feb 14, 2018 10:09 AM
JHL-ShinySideUp
Milwaukee Eight (M8)
11
Nov 25, 2017 03:49 PM
dinsmoor17
2014-2024 Touring Models
Jul 16, 2014 06:34 PM
