getting rubber/mesh off muffler?
Old Sep 19, 2006 | 03:22 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default getting rubber/mesh off muffler?
I got my mesh ridding pants on the muffler, nasty black spot.
How do i get it off? Someoner told me Easy Off oven cleaner. Metal polish won't touch it.
Thanks
Old Sep 19, 2006 | 03:25 PM
anubisss's Avatar
anubisss
Default RE: getting rubber/mesh off muffler?
Easy off oven cleaner. Do a search for it on here.
Old Sep 19, 2006 | 03:40 PM
mimo's Avatar
mimo
Keith,
With the bike COLD, remove as much as you can from the melted material using a thin razor blade, be very careful. To get rid of the rest, just use WHITE poolish, or some SIMICHROME. I've done it more than 5 times with excellent results every time.
PM if you have some questions.
Best regards.
Old Sep 19, 2006 | 03:45 PM
BeavisRules's Avatar
BeavisRules
Mr. Clean Magic Eraser for cars.
Believe it or not, those little white sponges will get almost anything off of chrome. I have melted the bottom of my boots and other things on the pipes and it came right off.
Old Sep 19, 2006 | 04:11 PM
KeithB's Avatar
KeithB
Thanks guys
Old Sep 19, 2006 | 04:26 PM
Steeltown's Avatar
Steeltown
acetone works the best
Old Sep 19, 2006 | 07:10 PM
KeithB's Avatar
KeithB
mimo, the thin razor blade did the trick
Old Sep 19, 2006 | 07:43 PM
zerotread's Avatar
zerotread
Easy Off worked like a champ when I had to get the remnants of a plastic bag off my pipes. DO NOT let it touch paint. The paint will be gone.
Old Sep 19, 2006 | 08:12 PM
electaRICK's Avatar
electaRICK
what I found works good,, after wife melted her heel.... I took out my butain torch, {for soldering} I heated up the spot till it got gooy, rubbed off with a rag,, then brake clean,,,, no razor scrapes
Old Sep 19, 2006 | 08:16 PM
DonFLSTN's Avatar
DonFLSTN
Might try spraying on a little carb cleaner.
