Master cyl. problem (help)
Old Nov 13, 2010 | 09:09 AM
brihvac's Avatar
brihvac
Well I guess I can either spend the $300 for chrome or put the stock black cyl on and change the clutch perch to black. Everything will be chrome except them. Damn-it. It was working fine.
Old Nov 13, 2010 | 01:47 PM
creatv1's Avatar
creatv1
I went through a similar issue with my aftermarket MC. Don't know if this will work for you, but it's something else to try. My guess is that when the MC was inverted, the trapped air at the top was pushed into the business end and you have a MC full of air.
With everything back together, turn your bars so the MC is as level as possible, pull the top off and start working the lever-- jiggle it a lot, push it hard to the out position a few times and see if you get bubbles in the MC when you pull the lever. If you do, keep playing with the lever until you actually get a spurt of fluid jumping out of the MC (cover your bike with something-- this gets a little messy and if you are using DOT4 could do some damage). The process could take a while. Also may help to tap on the lines with a screwdriver handle while doing this to work any bubbles out the top. This should get you at least some resistance to the lever. Put the top back on the MC, then do the mitivac again, then do the above process again.
I don't know how, or why, this worked for me-- but it did. Be patient, have a couple of beers, and good luck.
Old Nov 13, 2010 | 08:41 PM
1931jamesw's Avatar
1931jamesw
Originally Posted by oct1949
changed bars once and never got the brakes back to normal.... never do it again....
I buy the bike with the bars I want to keep now...
Are you saying you spend 16-17 grand on handlebars?
das56170
EVO
24
Oct 30, 2023 07:53 PM
2003sportster
Oct 29, 2014 08:05 AM
landslide03
Oct 3, 2012 09:51 PM
fatboy1729
Apr 27, 2012 02:00 PM
speedracer29
Mar 21, 2008 10:32 PM
