EVO rebuild
Old Nov 15, 2010 | 06:43 AM
carlgrover's Avatar
carlgrover
Sorry to hear that your motor didn't last too long. I run AMSOIL in my EVO and change every 5k. AMSOIL recommends changing at 10k! Yikes. Too long for me.
I'm curious, do you know how much oil you were losing inbetween oil changes? My mechanic told me it was normal for an EVO to burn about 1 qt ever 5k.
Old Nov 15, 2010 | 11:22 AM
hoethree's Avatar
hoethree
All very interesting comments from what sounds like people in the know. Begs my questions then. I have a 1999 FXR2 with the Evo and carb. My baby has 62K miles on it as she sits quietly on her throne in the Garage. I have NOT done anything but change fluids, replace brake pads, and buy tires. Seems to run just as strong as the day I brought her home. Would any one of you recommend an overhaul of the engine at this point? Always subscribed to the theory of if it aint broke, dont fix it. But I do wonder what the inside looks like. Someone told me that I should have changed out the pushrods TWICE by now but dont know why I would. I am not a motorhead and at best just a shadetree mechanic. Whats your opinion? thanks! Oh, I changed oil every 3K miles and have always ran HD Dino. Oil consumption has always been just under maybe a quart between changes and always looked good when changed.
Old Nov 15, 2010 | 12:34 PM
Fogoms's Avatar
Fogoms
I'd definitely leave it alone. Keep doing what you've been doing until the engine tells you its ready for an overhaul, which hopefuly won't be for many more miles yet. You want to know what the inside looks like? You'll find out one day, be patient. In the meantime you can get a good hint at the condition of the engine by reading your plugs and the fluids you drain out. And if changing out the pushrods isn't in the maintenance schedule, don't bother.
Old Nov 16, 2010 | 02:28 PM
LRS's Avatar
LRS
I lost 1/2 a qt between changes a time or two, but that was always at the times I went on long rides. One time on a ride from Atlanta to Ontario Canada, and once from atlanta out thru missouri.
If it aint broke I sure wouldnt mess with it.
Old Nov 16, 2010 | 04:40 PM
Faast Ed's Avatar
Faast Ed
When the sun hits "just right", do you see a hint of smoke coming out the pipes? You already said you didn't notice any other symptoms. If it ain't burning oil, I'd leave it alone.
Old Nov 16, 2010 | 06:21 PM
TwiZted Biker's Avatar
TwiZted Biker
Till that bike starts to feel tired or plugs begin fouling regular I would leave it alone , some of those Evo motors went way over 100,000 before rebuilds or just needing a top end done right off the showroom floor .
Old Nov 16, 2010 | 06:47 PM
yljkt's Avatar
yljkt
X2. My 85 FXRS went 85,000 when I re-ringed it and lapped the valves, new valve guide seals, and head and base gaskets. Sold it with over 100k. My 95 dresser was over 100,000 and except for an Andrews cam and other mods, never has the motor apart for a reason. Just winter mods. I ran cheap oil coolers on both, and ran dino oil changed frequently. Evo's seem pretty bullet proof.
Old Nov 16, 2010 | 09:01 PM
Jim Kraft's Avatar
Jim Kraft
The weak link in EVO's is the INA cam brg. I changed mine out with a Torrington at 27,000 miles on my 99, and it still looked great. Just a piece of mind thing for me. Lifters are another thing that need changed on some of the older ones. I run Castrol GTX 20-50 dino, and change it every 2,000 to 2,500 miles, just because so many EVO's have used this oil and run way over 100,000, and that is what was in it when I got it. Other than the cam brg. and adjustable pushrods, mine is stock, and will stay that way. It has way more power than I need, and my back tires last longer. LOL
Old Nov 17, 2010 | 03:20 AM
LRS's Avatar
LRS
He should have my engine back to me in a couple of weeks. I removed the oil tank last night and cleaned it very well. I never saw much of anything in it. I guess the filter caught the silt. I figured it bypassed and filled evrything up. When I removed the filter alot of crap came out. Looking forward to gettin her back togather!
Louie Champan
Sep 12, 2018 01:13 PM
fester1
EVO
41
Apr 16, 2018 10:10 AM
Axis39
Jun 30, 2016 05:15 PM
89FLHTC
EVO
45
May 13, 2016 02:31 PM
rabid rider
Nov 21, 2012 09:46 AM
