HELP! Bike Stalling/Hesitating
Old Nov 28, 2010 | 03:48 PM
nine11c2's Avatar
nine11c2
Default HELP! Bike Stalling/Hesitating
I have a 2004 Softail Deuce. I've done filter, V&H Big Shot Staggered, and remap. Bike ran great until about 3 months ago. Bike when riding stalls for a second. Sometimes feels like happens 2-3 times in a row. 2 or 3 times about 45 seconds after starts the bike almost stalls. I have gone thru 2-3 tanks of gas, put in fuel system cleaner, changed plugs, checked primary (too see if any play). Bike actually cuts out for split second when running. Sometimes hear chuffing sound.
Electrical? Do I need to chech chains? HELP!
Old Nov 28, 2010 | 03:57 PM
jarhead59's Avatar
jarhead59
yours sounds like it's rythmic, if so it's probably electronic (module) but i had one do it because of a bare spot in a wire that was shortin out. there should be a way to check the module I'd check for that online.
Old Nov 28, 2010 | 04:38 PM
Swede405's Avatar
Swede405
Check your battery, wires and connections. I've had similar issues and it was electrical.
Old Nov 28, 2010 | 05:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the electrical connections.
Old Nov 28, 2010 | 06:29 PM
ironmike41's Avatar
ironmike41
Check your battery connections. My Wideglide was acting the same way. I had both neg and pos connections were loose.
Old Nov 28, 2010 | 08:03 PM
BFREE's Avatar
BFREE
I had the same problem. Could be an electrical short somewhere. I found the wire going to the front fender tip light on my Heritage was broke where it goes into the fender. Haven't had a problem since I fixed it.
Old Feb 19, 2011 | 03:24 PM
nine11c2's Avatar
nine11c2
Default Done but..
I checked all the connections today. The bike "chuffed" once while warming up on the kickstand and twice while riding a couple of miles. My brother thinks the check engine lite stays on longer than normal and that the fuel pump sounds like its scavenging sometimes.
My bike isn't ridable - is the fuel pump goin? The pickup or fuel hose in the tank bad?
Old Feb 19, 2011 | 07:31 PM
carlgrover's Avatar
carlgrover
Yes. It might seem silly but a loose battery connection can do it. Don't just check at the battery, check the other ends as well.
Old Feb 19, 2011 | 09:02 PM
korey's Avatar
korey
Check you fuel pump relay.
Old Feb 19, 2011 | 09:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Check for codes and see what it says...
https://www.hdforums.com/forum/softa...odes-dtcs.html
