Mini Apes '08 FXDC DONE!!!
Old Dec 14, 2010 | 03:57 PM
dFREDb's Avatar
dFREDb
Default Mini Apes '08 FXDC DONE!!!
Thanks to the many members who have inspired me to tackle this job myself. I couldn't have done it without y'all! Here's a couple of pics of the finished product. I added 3 and 1/2 inch straight risers. The difference in comfort and handling is unbelievable and I learned so much about my bike in the process. Well worth the effort! Again, can't thank y'all enough! Fred
Attached Thumbnails Mini Apes '08 FXDC DONE!!!-dscf3914.jpg   Mini Apes '08 FXDC DONE!!!-dscf3915.jpg   Mini Apes '08 FXDC DONE!!!-dscf3916.jpg   Mini Apes '08 FXDC DONE!!!-dscf3917.jpg   Mini Apes '08 FXDC DONE!!!-dscf3918.jpg
Old Dec 14, 2010 | 04:20 PM
JerryL....'s Avatar
JerryL....
Mini apes are 10", those look more like 12". Either that, or you have hi risers on there. They look good.
Old Dec 14, 2010 | 05:37 PM
dFREDb's Avatar
dFREDb
Bars are from a 2011 Street Bob. I did add 3 and 1/2 inch straight risers. Thanks!
Old Dec 14, 2010 | 05:49 PM
Geezer2's Avatar
Geezer2
I love my apes. Very comfortable. I'm thinkin about adding some risers as well. Looks good!!
Old Dec 14, 2010 | 05:59 PM
dyna105's Avatar
dyna105
Looks good !! Have a set out in the shed waiting to be installed. Did you have to change any of your cables? Glad it went well for you,I have read a couple of other threads where you was a little worried about it. Now its my turn to worry a bit...lol
Old Dec 14, 2010 | 06:50 PM
dFREDb's Avatar
dFREDb
Just had the parts guy at Hammond Harley get the bars, clutch, brake, throttle and idle cables for a 2011 Street Bob. The bars are stainless internal wired and fit with stock FXDC clamps. Got the 3 and a half inch risers from JP Cycle. The only snag I ran into was that I had to drill the switch housings to internal wire the turn signals, but if you relocate to the forks you can bypass this little issue. Also got the Novello 8 inch wire extension kit. Worked like a charm. I would not get anything shorter than the 8's. I did have to lengthen the turn signal wires and solder the connections, but not hard. This is just a time consuming job at worst. The best part is I learned so much doing it myself. "ajpointless" has a step by step that took away nearly all my anxiety about tackling the job myself. To say it was worth it is an understatement!
If you have any questions, I would be more than happy to help you in any way I can. I really owe it to the guys here that went before me and helped with their advice. DO IT!!! You won't regret it. Fred
P.S. If you need part numbers I can dig up the receipts.
Old Dec 14, 2010 | 07:11 PM
dennyo's Avatar
dennyo
Congrats ,
Old Dec 14, 2010 | 08:45 PM
Kowan's Avatar
Kowan
Looks good. You ought to post a shot or two without the windshield.
It would make it easier to see for those thinking of using taller risers.
Old Dec 14, 2010 | 10:39 PM
rocknrick's Avatar
rocknrick
Looks good, and I think its great that you are so willing to pass along what you learned. Thats what this is all about. Congrads!
Old Dec 14, 2010 | 11:57 PM
RiverWolf's Avatar
RiverWolf
Looking good.
