Help!! Oil change
Old Dec 20, 2010 | 08:13 PM
chamokie's Avatar
chamokie
Make sure you pre-fill the filter prior to starting it. Other wise the engine will run without oil for a few seconds, not good. Prefill filter add oil and go for a ride.
Old Dec 20, 2010 | 09:45 PM
streeteagle's Avatar
streeteagle
I can't speak for anyone else but my oil level reads higher on the stick when good & hot as in the summer as compared to cooler weather, usually about a third of a quart. I use 3 & 1/2 quarts at change including pre-filling filter.
Old Dec 21, 2010 | 09:18 AM
Big_Al47's Avatar
Big_Al47
I put in 3-1/2 and it reads at the very bottom of the "add oil" portion of the dipstick. I will add another 1/4 quart and see what happens.
Old Dec 21, 2010 | 09:24 AM
SleeplessinVegas's Avatar
SleeplessinVegas
And how do you do that?
Old Dec 21, 2010 | 10:44 AM
red69camaro's Avatar
red69camaro
No chit.. Sounds like a mess to me. If a oil can't protect and engine for a few seconds then I would say it isn't very good oil.
Once you figure out how much oil to use, write it in your manual. I know mine is shy of the recommended amount. But I have trained my brain to automatically forget things like that.
Old Dec 21, 2010 | 10:59 AM
oct1949's Avatar
oct1949
The paper in the filter will soak up the oil, I just pour it bout 1/2 full, let it soak up and a little more, not so much it runs out when reinstalling the new one..
Old Dec 21, 2010 | 11:07 AM
NickD's Avatar
NickD
>>if you put the full 4 qts in and run it hard, you will (probably) end up with some oil puking out the ac.<<
Maybe it's just me, but I never understood that. I mean you could tow a fifty gallon drum full of oil behind you and your motor is only going to use as much oil as it normally uses. The head breathers blow out oil because it's a sucky EPA design change from the crankcase breathers that used to route that oil to the ground.
Old Dec 21, 2010 | 11:39 AM
Sharknose's Avatar
Sharknose
some folks could make a drink of water sound complicated......
Old Dec 21, 2010 | 12:19 PM
okrooster56's Avatar
okrooster56
4 qts motor, 1 qt primary, 1 qt tranny, it ain't rocket science.
Old Dec 21, 2010 | 04:18 PM
dawg's Avatar
dawg
It's actually 38oz primary, not 1 qt...just sayin'
msengel
May 11, 2024 07:50 PM
rysonn
Oct 2, 2016 06:00 AM
texx
Jun 4, 2009 10:42 PM
csc133
Oil Archive (no new posts)
Apr 24, 2007 02:20 PM
Jezcruzen
Aug 8, 2005 12:33 PM
